Home » Modeling » TMF (Xtext) » Problem building with Tycho - can't resolve eclipselabs unit testing bundle - SOLVED
Problem building with Tycho - can't resolve eclipselabs unit testing bundle - SOLVED [message #912065] Wed, 12 September 2012 17:58 Go to next message
Scott Finnie is currently offline Scott Finnie
Member
Apologies, new to tycho and maven.
Trying to build update site for my xtext project using tycho. Project uses the eclipse labs unit testing framework; works in the IDE fine but causes tycho to barf:
Unable to satisfy dependency from org.domainmodels.ooa 0.0.1 to bundle org.eclipselabs.xtext.utils.unittesting 0.0.0.
Guessing I just need to tell maven where/how to find the bundle...just don't know where/how to do that.
Would appreciate pointer. Thanks.
[Updated on: Wed, 12 September 2012 18:17]
Report message to a moderator
Re: Problem building with Tycho - can't resolve eclipselabs unit testing bundle - SOLVED [message #912074 is a reply to message #912065] Wed, 12 September 2012 18:21 Go to previous message
Member
Solved as follows:
In root pom.xml, added a new property:
  <properties>
    <!-- other properties... />
    <eclipselabs-site>http://xtext-utils.eclipselabs.org.codespot.com/git.distribution/releases/unittesting-0.9.x</eclipselabs-site>
  </properties>
..and a repo that uses it:
  <repositories>
    <!-- other repos...>
    <repository>
      <id>eclipselabs</id>
      <layout>p2</layout>
      <url>${eclipselabs-site}</url>
    </repository>
  </repositories>
Then re-ran mvn clean & all worked ok.
Previous Topic:Creating a Graphiti editor on top of Xtext editor
Next Topic:Problem with contentassist antlr in ui project
Current Time: Mon May 20 17:26:32 EDT 2013
Powered by FUDForum. Page generated in 0.01467 seconds
