Home » Eclipse Projects » BPMN 2.0 Modeler » Problems with targetNamespace(Value of targetNamespace not valid)
Problems with targetNamespace [message #910711] Mon, 10 September 2012 05:02 Go to next message
paco gutierrez is currently offline paco gutierrez
I'n new in BPMN and ATL and I begin working with ATL transformations from BPMN 2.0 to other languages.
I've problems when I run the transformations.
I've an error in the XMI file of the model: "value of TargetNamespace is not legal".
I've tested with several (normally corrects) values and I've always the same error.
I think that's would be related with the issue (16398) in www.omg.org/issues/bpmn2-rtf.open.html:
Issue 16398: XML Schema not valid (bpmn2-rtf)
Nature: Clarification
Severity: Significant
Summary:
The official XML Schema for BPMN 2.0 (www.omg.org/spec/BPMN/20100501/BPMN20.xsd) is not valid.
- It imports a schema with the schemaLocation "www.omg.org/spec/BPMN/20100501/Diagram Interchange.xsd", which does not exist.
Even when using the correct schemaLocation of "www.omg.org/spec/BPMN/20100501/DI.xsd", the namespace does not match (www.omg.com/di/1.0.0 vs. www.omg.org/spec/DD/20100524/DI)
(Note that one uses "omg.com" and the other uses "omg.org".)
- It includes the Schema "www.omg.org/spec/BPMN/20100501/Semantic.xsd", but its targetNamespace www.omg.org/spec/BPMN/20100524/MODEL does not match the including schema's value.
- The website www.omg.org/spec/BPMN/2.0/ has missmatching links for several items:
-- "www.omg.org/spec/BPMN/20100501/DI.xsd" links to "www.omg.org/spec/BPMN/20100501/BPMNDI.xsd"
-- "www.omg.org/spec/BPMN/20100501/Semantic.xsd" links to " www.omg.org/spec/BPMN/20100501/BPMNDI.xsd"
Resolution:
Revised Text:
Actions taken:
July 28, 2011: received issue
I've send a comment on this issue to bpmn2-rtf@omg.org like it's suggested in the site refered above, but no reply still.
Anyone knows if there is a solution for the problem related with this issue or if it's other the problem I have?
Thanks in advance.
Paco.
Re: Problems with targetNamespace [message #910874 is a reply to message #910711] Mon, 10 September 2012 10:48 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Maybe this is a question for the BPMN2 metamodel group, here: mdt-bpmn2.dev@eclipse.org
Re: Problems with targetNamespace [message #911717 is a reply to message #910874] Wed, 12 September 2012 03:16 Go to previous message
Thanks.
I'm new in modelling (BPMN, ATL, EMF, ...) and I don't know well.
I'll ask my question there.
Previous Topic:Problems with ImageProvider
Next Topic:Is latest BPMN2 Modeler compatible with Eclipse 3.8??
Current Time: Sat May 18 16:31:35 EDT 2013
Powered by FUDForum. Page generated in 0.01537 seconds
