Home » Modeling » EMF » Comparing EObjects with EcoreUtils
Comparing EObjects with EcoreUtils [message #911425] Tue, 11 September 2012 11:22 Go to next message
El Arbi Aboussoror is currently offline El Arbi Aboussoror
Member
I have troubles with the equals(EObject, EObject) method in EcoreUtils.
I have loaded the same xmi resource twice and have written a test that compares Transition eobjects and then another test that compares Action eobjects and I don't understand why the first test passes while the second fails !?
@Test
	public void testActions() {
		Transition enabledTrans = (Transition) enabledTransRes.getContents()
				.get(0);
		Transition scenarioTrans = (Transition) scenarioTransRes.getContents()
				.get(0);
		for (int i = 0; i < enabledTrans.getActions().size(); i++) {
			Action enabledAction = enabledTrans.getActions().get(i);
			Action scenarioAction = scenarioTrans.getActions().get(i);
			System.err.println("i:"+i+" kind:"+scenarioAction.getKind());
			assertTrue(EcoreUtil.equals(enabledAction, scenarioAction));
	@Test
	public void testTansition() {
				.get(0);
				.get(0);
		assertTrue(EcoreUtil.equals(enabledTrans, scenarioTrans));
I have attached a test project.
[Updated on: Tue, 11 September 2012 12:05]
Report message to a moderator
Re: Comparing EObjects with EcoreUtils [message #911433 is a reply to message #911425] Tue, 11 September 2012 11:35 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
The test looks like this:
public void setUp() throws Exception {
EPackage.Registry.INSTANCE.put(IFConfigPackage.eNS_URI,
IFConfigPackage.eINSTANCE);
scenarioTransRes
.setURI(URI
..createFileURI("D:/workspaces/wp_irit_ifx/fr.irit.ifx.test/src/fr/irit/ifclipse/controller/tests/dump/scenarioTransRess.xmi"));
enabledTransRes
.setURI(URI
scenarioTransRes.load(null);
enabledTransRes.load(null);
So I can't run it because it's not self contained. Please put the test
data in the test project and use a relative path to locate it so it
doesn't matter where I install the project; I believe the project itself
will be set to be the current working directly...
On 11/09/2012 5:22 PM, ElArbi Mising name wrote:
> Hello,
> I have loaded the same xmi resource twice and have written a test that compares a Transition eobjects and then another test that compares Action eobjects and I don't understand why the first test passes while the second fails !?
> @Test
> .get(0);
> .get(0);
> @Test
> .get(0);
> .get(0);
Re: Comparing EObjects with EcoreUtils [message #911449 is a reply to message #911433] Tue, 11 September 2012 12:06 Go to previous messageGo to next message
Member
I have updated the attachement.
It should now work corretly.
Re: Comparing EObjects with EcoreUtils [message #911454 is a reply to message #911449] Tue, 11 September 2012 12:21 Go to previous messageGo to next message
You didn't attach it though. :-P
Re: Comparing EObjects with EcoreUtils [message #911461 is a reply to message #911454] Tue, 11 September 2012 12:41 Go to previous messageGo to next message
Member
I have simply changed the attachement to my first message.
Re: Comparing EObjects with EcoreUtils [message #911498 is a reply to message #911461] Tue, 11 September 2012 14:27 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Your model is a little strange.&nbsp; It has actions that are definition
structurally equal to each other, e.g.,<br>
<blockquote>&nbsp; &lt;actions kind="IMPORT" value=""&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;by name="u2i__default_constructor_Default_System"/&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;from name="Default_System"/&gt;<br>
&nbsp; &lt;/actions&gt;<br>
</blockquote>
Then I noticed you did this:<br>
<br>
&nbsp;&nbsp;&nbsp; @Override<br>
&nbsp;&nbsp;&nbsp; public int hashCode() {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; final int prime = 31;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; int result = 1;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; result = prime * result + ((name == null) ? 0 :
name.hashCode());<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; result = prime * result + number;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return result;<br>
&nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; public boolean equals(Object obj) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (this == obj)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return true;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (obj == null)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return false;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (!(obj instanceof PidImpl))<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; PidImpl other = (PidImpl) obj;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (name == null) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (other.name != null)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return false;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; } else if (!name.equals(other.name))<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (number != other.number)<br>
<br>
That violates this constraint document in EObject:<br>
<blockquote>The framework also assumes that implementations will not
specialize <code><a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82%E2%98%82equals%E2%98%82Object">equals(Object)</a></code>
(nor <code><a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82%E2%98%82hashCode%E2%98%82">hashCode()</a></code>)
so that "<code>==</code>" can be always used for equality testing;
<code><a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82org.eclipse.emf.ecore.util.EcoreUtil%E2%98%82equals%E2%98%82EObject%E2%98%82EObject">EcoreUtil.equals</a></code>
should be used for doing structural equality testing. <br>
</blockquote>
Why do you do this?&nbsp; It's generally a bad idea to define equality
and hashCodes for values that are mutable...<br>
<br>
<br>
<div class="moz-cite-prefix">On 11/09/2012 6:41 PM, ElArbi Mising
name wrote:<br>
</div>
<blockquote cite="mid:k2npis$srb$1@xxxxxxxxe.org" type="cite">
<pre wrap="">I have simply changed the attachement to my first message.
</pre>
</blockquote>
<br>
</body>
</html>
Re: Comparing EObjects with EcoreUtils [message #911507 is a reply to message #911498] Tue, 11 September 2012 14:52 Go to previous messageGo to next message
Member
Thank you for your reply but your message is hardly readable, did you sent it in html format ?
I'm reading from here: http://www.eclipse.org/forums/index.php/t/375238/
Re: Comparing EObjects with EcoreUtils [message #911540 is a reply to message #911507] Tue, 11 September 2012 16:35 Go to previous messageGo to next message
Your model is a little strange. It has actions that are definition
<actions kind="IMPORT" value="">
<by name="u2i__default_constructor_Default_System"/>
<from name="Default_System"/>
</actions>
</actions>
int result = 1;
result = prime * result + ((name == null) ? 0 : name.hashCode());
return result;
if (this == obj)
return true;
if (obj == null)
return false;
return false;
if (name == null) {
return false;
return false;
return false;
return true;
The framework also assumes that implementations will not specialize
|equals(Object)
<eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82%E2%98%82equals%E2%98%82Object>|
(nor |hashCode()
<eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82%E2%98%82hashCode%E2%98%82>|)
so that "|==|" can be always used for equality testing;
|EcoreUtil.equals
<eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.eclipse.emf.ecore%7BEObject.java%E2%98%83EObject%E2%98%82org.eclipse.emf.ecore.util.EcoreUtil%E2%98%82equals%E2%98%82EObject%E2%98%82EObject>|
Why do you do this? It's generally a bad idea to define equality and
Re: Comparing EObjects with EcoreUtils [message #911543 is a reply to message #911540] Tue, 11 September 2012 16:37 Go to previous messageGo to next message
I tried plain text. Here's the Javadoc for EObject:
http://download.eclipse.org/modeling/emf/emf/javadoc/2.8.0/org/eclipse/emf/ecore/EObject.html
> </actions>
> </actions>
> @Override
> int result = 1;
> return result;
> @Override
> if (this == obj)
> return true;
> if (obj == null)
> return false;
> return false;
> if (name == null) {
> return false;
> return false;
> return false;
> return true;
> |equals(Object)
> (nor |hashCode()
> |EcoreUtil.equals
Re: Comparing EObjects with EcoreUtils [message #911707 is a reply to message #911540] Wed, 12 September 2012 03:05 Go to previous messageGo to next message
Member
Ed Merks wrote on Tue, 11 September 2012 16:35
</actions>
</actions>
This is strange but it is a derived model (from parsing some XML traces...)
[quote title=Ed Merks wrote on Tue, 11 September 2012 16:35]
int result = 1;
return result;
if (this == obj)
return true;
if (obj == null)
return false;
return false;
if (name == null) {
return false;
return false;
return false;
return true;
|equals(Object)
(nor |hashCode()
|EcoreUtil.equals
[/quote]
I have generated equals and hashCode methods to be able to use java.util.Set for the Pid Eobjects, please see testPidRegistry() method in the EcoreUtilTest class in the attached project.
	@Test
	public void testPidRegistry() {
		PidRegistry registry = new PidRegistry();
		// store a Pid twice
		Pid server1 = IFConfigFactory.eINSTANCE.createPid();
		server1.setName("Server");
		server1.setNumber(0);
		Pid server2 = IFConfigFactory.eINSTANCE.createPid();
		server2.setName("Server");
		server2.setNumber(0);
		// check that there's no duplicates
		registry.store(server1);
		assertEquals(1, registry.size());
		registry.store(server2);
I haven't found in the Elist implementations something that do the same as Set... I'm wrong ?
Re: Comparing EObjects with EcoreUtils [message #911720 is a reply to message #911707] Wed, 12 September 2012 03:20 Go to previous messageGo to next message
Comments below.
>> </actions>
>> </actions>
Oh well, in the end this thing causes a problem in the equality code
because the map finds the wrong object. Someone complained that I
should have used an IdentityHashMap, which is true, but it's an API
breaking change, and I don't do those as a general rule. And it
shouldn't be necessary given the documented constraints on EObject
implementations...
> @Override
> int result = 1;
> return result;
> @Override
> if (this == obj)
> return true;
> if (obj == null)
> return false;
> return false;
> if (name == null) {
> return false;
> return false;
> return false;
> return true;
> |equals(Object)
> (nor |hashCode()
> |EcoreUtil.equals
> [/quote]
> @Test
Consider that most of the of the ELists for managing EObject require the
object to be in the list at most once. So the framework needs to do a
lot of List.contains testing which turns out to be very expensive
because of so many calls to .equals. The following approach in
BasicEList optimizes that nicely by using == instead of equals.
public boolean contains(Object object)
if (useEquals() && object != null)
for (int i = 0; i < size; ++i)
if (object.equals(data[i]))
return true;
else
if (data[i] == object)
return true;
return false;
So all EMF's list implementations for EObjects override useEquals to be
false and drop into the fast implementation. But that's valid behavior
for such a list only if (o1 == o2) == (o1.equals(o2)) which is the case
only if the object doesn't override hashCode and equals. You might
argue next, so what, but if you consider that you have an EMF
implementation List, x, and do x.contains(o) and it returns false, but
then you do "new ArrayList(x).contains(o)" and it returns true, because
the former uses == but that later uses .equals for testing, then you
have confusing inconsistent behavior.
So that's the way it is and it's not going to change. If you choose to
ignore that, you'll run into problems like the one you found and there
will be other problems you've not noticed yet.
Re: Comparing EObjects with EcoreUtils [message #912001 is a reply to message #911720] Wed, 12 September 2012 14:59 Go to previous message
Member
Ok I've catch the point.
Thank you for this detailed answer.
Previous Topic:Many Packages and ManyModelFiles -> No Refs Model load
Next Topic:[XCore] derived feature, manual code
Current Time: Wed May 22 16:23:10 EDT 2013
Powered by FUDForum. Page generated in 0.06187 seconds
