Home » Eclipse Projects » Rich Client Platform (RCP) » Combining pulldown and toggle styles for a command in the plugin.xml
Combining pulldown and toggle styles for a command in the plugin.xml [message #911207] Tue, 11 September 2012 03:27 Go to next message
Cedric Moonen is currently offline Cedric Moonen
I need to add a command to my view toolbar which acts as a toggle button. Furthermore, it should also have the dropdown style.
Unfortunately, the plugin.xml only allows the selection of one style. Is there a way to combine those two styles ?
Re: Combining pulldown and toggle styles for a command in the plugin.xml [message #923153 is a reply to message #911207] Tue, 25 September 2012 12:47 Go to previous message
Paul Webster is currently offline Paul Webster
No, the SWT toolitem only supports toggle or dropdown, not both at the same time.
PW
Previous Topic:Custom Errors
Next Topic:Process for adding custom language validation for Eclipse 3.x RCP?
Current Time: Wed May 22 16:16:16 EDT 2013
Powered by FUDForum. Page generated in 0.01437 seconds
