| Problems with ImageProvider [message #910535] |
Sun, 09 September 2012 19:47  |
Dominik Thalmann Messages: 11 Registered: May 2012 |
Junior Member |
Hey everyone,
I have three concerns. First thing is that I cant load images with my own ImageProvider. Below is the code for my ImageProvider and a link to a picture where you can see what the result looks like. I just see a red square on the editor. If I use the ImageProvider from the bpmn modeler the picture loads just fine and everything works... It seems as if my picture isnt found although it is there in the folder icons.
The second question: Is it possible to add a picture on the elements in the palette? SO that I have a small picture for all my new elements... It would be the same as on the diagram but just a bit smaller.
The third question is: Can I somehow change the name of the CustomTask Container on the palette without having to edit the BPMN Modeler code? I would like to have a Container thats called "ROSI Elements" or something instead of "Custom Task".
Here is the code for my ImageProvider:
package org.eclipse.bpmn2.modeler.runtime.rosi.extension;
import org.eclipse.graphiti.ui.platform.AbstractImageProvider;
public class RosiImageProvider extends AbstractImageProvider {
public static final String RISK = "Risk";
public RosiImageProvider() {
// TODO Auto-generated constructor stub
protected void addAvailableImages() {
// TODO Auto-generated method stub
addImageFilePath(RISK, "icons/risk.png");
System.out.println("Images added.");
And here is the code where I want to use the image with the RISK-ID in my addFeature:
public IAddFeature getAddFeature(IFeatureProvider fp) {
return new AddCustomTaskFeature(fp) {
protected void decorateActivityRectangle(RoundedRectangle rect) {
IGaService service = Graphiti.getGaService();
Image img = service.createImage(rect, RosiImageProvider.RISK);
service.setLocationAndSize(img, 2, 2,
GraphicsUtil.TASK_IMAGE_SIZE,
GraphicsUtil.TASK_IMAGE_SIZE);
The link for the result (the red square in the left-top corner of the task should be my picture):
www7.pic-upload.de/10.09.12/7zfrz6qnusz.png
[Updated on: Sun, 09 September 2012 19:48] Report message to a moderator
| Re: Problems with ImageProvider [message #910842 is a reply to message #910535] |
Mon, 10 September 2012 09:31  |
Hi Dominik,
This is an area of Graphiti that I don't have a lot of familiarity with, so you may want to experiment with a few things... first, did you add the imageprovider extension to your plugin.xml? (see the jbpm5 plugin for example) Make sure your ImageProvider's addAvailableImages() is getting called! If that doesn't work, try adding your images to the Graphiti image registry directly, like so:
ImageDescriptor image = ImageDescriptor.createFromURL(url);
ImageRegistry imageRegistry = GraphitiUIPlugin.getDefault().getImageRegistry();
if (imageRegistry.get(iconPath) == null)
imageRegistry.put(iconPath, image);
As far as your third question, I'm afraid the answer is no - there is no editor extension point to add new palette drawers, or change the draw titles at this time but you can always request this as a new feature in bugzilla
HTH,
Bob
FUDForum. Page generated in 0.23861 seconds
