Home » Modeling » QVT-OML » Strange reference to UCharacter in RunnableQVTParser
Strange reference to UCharacter in RunnableQVTParser [message #910817] Mon, 10 September 2012 08:40 Go to next message
Eclipse User
I'm somewhat confused by the following method:
org.eclipse.m2m.internal.qvt.oml.ast.parser.QvtOperationalParser.RunnableQVTParser.computeInputString(int,
int)
I accidentally reached this method due to a stupid syntax error and when
the line
if (!UCharacter.isWhitespace(chars[i-1])) {
was to be executed, "UCharacter" could not be found and I received a
NoClassDefFoundError exception. I don't know this class and I'm already
pretty confused by the fact that within this calling module it is
imported as "com.ibm.icu.lang.UCharacter", but when I select "Open
Declaration" I'm shown "sun.text.normalizer.UCharacter". So I suspect
some classpath trickery here. What do I need to do/declare to have this
properly working?
TIA
Marius
Re: Strange reference to UCharacter in RunnableQVTParser [message #910823 is a reply to message #910817] Mon, 10 September 2012 08:57 Go to previous messageGo to next message
Eclipse User
On 10.09.2012 14:40, Marius Gröger wrote:
> Hello,
> int)
> the line
> properly working?
I think I found it. The method in question depends on
com.ibm.icu_XXX.jar. My classpath didn't include this jar, so eclipse
apparently tried to resolve on its own as best as possible and used the
version in rt.jar. When actually executing the code, the class loaded
just could not find UCharacter.
Marius
Re: Strange reference to UCharacter in RunnableQVTParser [message #910863 is a reply to message #910823] Mon, 10 September 2012 10:15 Go to previous message
My workspace shows just com.ibm.icu.lang.UCharacter which is just one of
a number of standard classes extended by IBM.
Hopefully these enhancements will merge now that java is moving again.
I presume from your comments that your problem is fixed.
Ed Willink
>> Hello,
>> int)
>> the line
>> properly working?
> Marius
Previous Topic:EMF Generics and QVT-O
Next Topic:Exception when invoking a helper method
Current Time: Thu May 23 13:57:49 EDT 2013
Powered by FUDForum. Page generated in 0.01571 seconds
