Home » Eclipse Projects » GEF » Blend Selection and Marquee
Blend Selection and Marquee [message #904941] Wed, 29 August 2012 08:26 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
I want to selection tool to have marquee tool functionality as well. Normally in graphical application user donot have to select marquee to select multiple objects with mouse, it can be done with selection tool.
any idea?
Re: Blend Selection and Marquee [message #910776 is a reply to message #904941] Mon, 10 September 2012 07:30 Go to previous message
Jan Krakora is currently offline Jan Krakora
You have to return the MarqueeDragTracker from getDragTracker(Request req) of your content edit part. Then it should just work even if you have the SelectionTool active.
Previous Topic:Moving parent
Next Topic:Zoom on gef shapes example
Current Time: Tue May 21 15:50:18 EDT 2013
Powered by FUDForum. Page generated in 0.01645 seconds
