| Problems with targetNamespace [message #910688] |
Mon, 10 September 2012 04:12  |
paco gutierrez Messages: 7 Registered: September 2012 |
Junior Member |
I'n new in BPMN and ATL and I begin working with ATL transformations from BPMN 2.0 to other languages.
I've problems when I run the transformations.
I've an error in the XMI file of the model: "value of TargetNamespace is not legal".
I've tested with several (normally corrects) values and I've always the same error.
I think that's would be related with the issue (16398) in www.omg.org/issues/bpmn2-rtf.open.html:
Issue 16398: XML Schema not valid (bpmn2-rtf)
Nature: Clarification
Severity: Significant
Summary:
The official XML Schema for BPMN 2.0 (www.omg.org/spec/BPMN/20100501/BPMN20.xsd) is not valid.
- It imports a schema with the schemaLocation "www.omg.org/spec/BPMN/20100501/Diagram Interchange.xsd", which does not exist.
Even when using the correct schemaLocation of "www.omg.org/spec/BPMN/20100501/DI.xsd", the namespace does not match (www.omg.com/di/1.0.0 vs. www.omg.org/spec/DD/20100524/DI)
(Note that one uses "omg.com" and the other uses "omg.org".)
- It includes the Schema "www.omg.org/spec/BPMN/20100501/Semantic.xsd", but its targetNamespace www.omg.org/spec/BPMN/20100524/MODEL does not match the including schema's value.
- The website www.omg.org/spec/BPMN/2.0/ has missmatching links for several items:
-- "www.omg.org/spec/BPMN/20100501/DI.xsd" links to "www.omg.org/spec/BPMN/20100501/BPMNDI.xsd"
-- "www.omg.org/spec/BPMN/20100501/Semantic.xsd" links to " www.omg.org/spec/BPMN/20100501/BPMNDI.xsd"
Resolution:
Revised Text:
Actions taken:
July 28, 2011: received issue
I've send a comment on this issue to bpmn2-rtf@omg.org like it's suggested in the site refered above, but no reply still.
Anyone knows if there is a solution for the problem related with this issue or if it's other the problem I have?
Thanks in advance.
Paco.
| Re: Problems with targetNamespace [message #910865 is a reply to message #910688] |
Mon, 10 September 2012 10:24   |
Hugo Bruneliere Messages: 467 Registered: July 2009 |
Which BPMN2 metamodel implementation are you using? The one from the MDT-BPMN2 project?
In any case, before any transformation or further handling, you should first check that your input BPMN model is valid by trying to open it with the Sample Reflective Ecore Model Editor for instance.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
FUDForum. Page generated in 0.01738 seconds
