Home » Eclipse Projects » Eclipse 4 » E4 Test Suites
E4 Test Suites [message #910282] Sun, 09 September 2012 02:40
Joseph Carroll is currently offline Joseph Carroll
I was looking to run the test suites in bundle org.eclipse.e4.core.tests and have been unsuccessful. I tried running the CoreTestSuite using the launch configuration included in the bundle and from the command line according to the testframework.html, but neither worked.
I thought I would try using the test.xml ant file, so I went through and changed the properties to reflect my environment (see attached). However that still does not work.
I was hoping to measure some performance differences for several patches, any insight would be appreciated.
Thanks, Smile
JD
Previous Topic:Extending swt-shell in another plugin
Next Topic:org.eclipse.ui.views.properties error
Current Time: Fri May 24 09:15:29 EDT 2013
Powered by FUDForum. Page generated in 0.02165 seconds
