| Re: Extending swt-shell in another plugin [message #909809 is a reply to message #909793] |
Fri, 07 September 2012 16:56   |
Thomas Schindl Messages: 4462 Registered: July 2009 |
No extension points at your own code is fine. What is replaced in e4 are
the many many extension points we had in e3 (views, menus, commands, ...).
There's nothing wrong we creating them for your own extension story.
Tom
Am 07.09.12 22:07, schrieb Markus Oley:
> Hi Sopot,
> thanks for your answer, I'll try it to ask in a more concrete way:
> I have one plugin A, were I have a shell to edit users. I have another
> plugin B, which should add a functionality to this user-shell, in this
> case a button were I can jump to another shell, were I can edit
> preferences of the currently selected user. This second shell is part of
> plugin B, but should not be coupled to plugin A.
> I want the button only to be shown, when plugin B is installed otherwise
> the button should be not visible.
> How do I implement this scenario with E4?
> In E3.x I would have defined an extension point in plugin A for example.
> In plugin B I would implement this extension point. But I think in e4
> extension points shall be replaced by the model and so my question is:
> Is there any technique in application model which can replace the
> extension points in this case?
> Best regards Markus
FUDForum. Page generated in 0.01666 seconds
