| Mirror update site problem [message #904191] |
Mon, 27 August 2012 21:07  |
Ted Williams Messages: 2 Registered: August 2012 |
Junior Member |
I am trying to mirror the m2e plugin so I can install @ work in an offline env.
I followed instructions from here:
http://wiki.eclipse.org/Equinox_p2_Repository_Mirroring
Using the following commands:
eclipse -nosplash -verbose
-application org.eclipse.equinox.p2.metadata.repository.mirrorApplication
-source http://download.eclipse.org/technology/m2e/releases
-destination c:\tmp\m2e
-application org.eclipse.equinox.p2.artifact.repository.mirrorApplication
-source [url]http://download.eclipse.org/technology/m2e/releases[/url]
However when I take my eclipse offline and try to install from that
local update site I get the following error:
Cannot complete the install because one or more required items could
not be found.
Software being installed: m2e - slf4j over logback logging
(Optional) 1.1.0.20120530-0009
(org.eclipse.m2e.logback.feature.feature.group 1.1.0.20120530-0009)
Missing requirement: Maven Project Model Edit Bundle
1.1.0.20120530-0009 (org.eclipse.m2e.model.edit 1.1.0.20120530-0009)
requires 'bundle org.eclipse.emf.ecore.xmi 0.0.0' but it could not be
found
Cannot satisfy dependency:
From: Maven Integration for Eclipse 1.1.0.20120530-0009
(org.eclipse.m2e.core.ui 1.1.0.20120530-0009)
To: bundle org.eclipse.m2e.model.edit [1.1.0,1.2.0)
(org.eclipse.m2e.logback.appender 1.1.0.20120530-0009)
To: bundle org.eclipse.m2e.core.ui [1.1.0,1.2.0)
1.1.0.20120530-0009 (org.eclipse.m2e.logback.feature.feature.group
To: org.eclipse.m2e.logback.appender [1.1.0.20120530-0009]
I would think there would be a way to mirror such that all dependencies would be included.
I search for 'bundle org.eclipse.emf.ecore.xmi 0.0.0' but could not really find anything. How am I supposed to mirror that dependency as well?
The point of mirroring a p2 site is so that you can install the plugin offline. Anyone have any ideas? I am wondering if the m2e p2 site is setup correctly. Or maybe there is a different way to mirror p2 sites.
Thanks in advance
[Updated on: Mon, 27 August 2012 21:07] Report message to a moderator
FUDForum. Page generated in 0.03267 seconds
