Home » Eclipse Projects » Rich Client Platform (RCP) » Custom MRU list
Custom MRU list [message #909459] Fri, 07 September 2012 03:18
Cedric Moonen is currently offline Cedric Moonen
My application can load files which contain a list of elements that can be edited. The application can load one file at a time and displays the list of element in a view. When double-clicking on an element, it can be edited via its editor. So, in fact, opening such a file is more or less similar as switching workspace in Eclipse (you don't open the file in an editor but you reload the contents of the file to populate the application).
I would like to have the concept of MRU but not based on editors which were opened but rather on the files which were opened.
How could I achieve something like that ? As far as I understood, MRU is managed IEditorInput (not fully sure here, I couldn't find too much info about that).
Do I have to manage the MRU myself (each time a file is opened, persist the path, then update the MRU list manually, ...) ?
Previous Topic:JUNO - Changes to Class Perspective
Next Topic:SqlStatementArea (sourceviewer) code completion doesn't work
Current Time: Sun May 26 04:21:08 EDT 2013
Powered by FUDForum. Page generated in 0.01891 seconds
