Home » Eclipse Projects » Buckminster » import org.tmatesoft.svn.core.wc cannot be resolved(Import error reported during build)
import org.tmatesoft.svn.core.wc cannot be resolved [message #906116] Fri, 31 August 2012 12:45 Go to next message
Alex Kravets is currently offline Alex Kravets
One of my plugins uses classes from org.tmatesoft.svn.core.wc package which is being imported by the plugins via package. When I build product in IDE org.tmatesoft.svnkit feature and org.tmatesoft.svn.core.wc plugin make it into p2 repository and product build fine. However, when I build in Jenkins, during 'build' call I get error about import of org.tmatesoft.svn.core.wc not being resolved. Any ideas what can cause this error?
Alex
[Updated on: Fri, 31 August 2012 12:47]
Report message to a moderator
Re: import org.tmatesoft.svn.core.wc cannot be resolved [message #906128 is a reply to message #906116] Fri, 31 August 2012 13:00 Go to previous messageGo to next message
I checked target platform and org.tmatesoft.svnkit_1.3.5.7406.jar includes svnkit.jar and all packages are being exported from there. However, import errors occur regardless. I did try to add svnkit.jar in my plugin and add it to classpath, which works, however, I don't think I need to do this, do I?
Re: import org.tmatesoft.svn.core.wc cannot be resolved [message #906165 is a reply to message #906128] Fri, 31 August 2012 15:00 Go to previous messageGo to next message
I think I might need to install svn feature to my buckminster headless install, will try it...
Re: import org.tmatesoft.svn.core.wc cannot be resolved [message #908542 is a reply to message #906165] Wed, 05 September 2012 10:48 Go to previous messageGo to next message
Alex Kravets wrote on Fri, 31 August 2012 15:00
The only thing that seems to work in adding svnkit.jar directly in my plugin. Is that the right way to do it?
Re: import org.tmatesoft.svn.core.wc cannot be resolved [message #909175 is a reply to message #908542] Thu, 06 September 2012 13:15 Go to previous message
Once I add svnkit.jar and run from IDE everything works. However, when I build the product I see that SVNKit Library Plugin is not being added which is present when I run from IDE. If I manually add SVNKit plugin jar in the build's plugin directory than everything works as during IDE run.
Previous Topic:Resolving org.swtchart
Next Topic:Source feature generation broken?
Current Time: Sat May 18 18:36:35 EDT 2013
Powered by FUDForum. Page generated in 0.01689 seconds
