Home » Modeling » Graphiti » Layout after shape.setVisible
Layout after shape.setVisible [message #908417] Wed, 05 September 2012 06:51 Go to next message
Rui Domingues is currently offline Rui Domingues
Hi.
I have a layout feature, that simply set true or false the visible property of a non-active shape, however visually nothing happens. Otherwise, if I addicionally invoke something like setX in the respective GA, the layout happens as it should.
Am I missing something? This is the expected behaviour?
If this is the expected behaviour, there is anyaway of "touching" GA ?
Rui
[Updated on: Wed, 05 September 2012 06:56]
Report message to a moderator
Re: Layout after shape.setVisible [message #908547 is a reply to message #908417] Wed, 05 September 2012 10:49 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Rui,
can you check if your update feature is being called? And if yes, if it
checks that change and tells the Graphiti framework that an update is
needed?
Michael
Re: Layout after shape.setVisible [message #908572 is a reply to message #908547] Wed, 05 September 2012 11:31 Go to previous messageGo to next message
Yes. Update feature is being called, it checks update is needed, update is done, and shape is not becoming visible, unless I programmatically, change something in GA.
The cenario is:
I have two images which switch shape's visible property, exclusively.
Re: Layout after shape.setVisible [message #909073 is a reply to message #908572] Thu, 06 September 2012 09:40 Go to previous message
Sounds like a bug. Can you extract that as a small reproducable example and
create a bugzilla for it?
Michael
Previous Topic:How to Outline
Next Topic:Add feature (inside not active container shape)
Current Time: Sat May 18 06:03:09 EDT 2013
Powered by FUDForum. Page generated in 0.01657 seconds
