Home » Eclipse Projects » EclipseLink » Eclipselink 2.3.2 + composite persistence units + bean validation (jsr303)
Eclipselink 2.3.2 + composite persistence units + bean validation (jsr303) [message #905060] Wed, 29 August 2012 11:59 Go to next message
Maciej Jaśkowski is currently offline Maciej Jaśkowski
Does any one know why such a configuration is not supported? Or even better how to make it work, anyway?
I say that it doesn't work because one can see in the code of EntityManagerSetupImpl:
if (!isCompositeMember()) {
    addBeanValidationListeners(deployProperties, realClassLoader);
in lines 431-433
which basically means: if the pu in question is composite member then now validation listeners is added.
On the other hand the "master" no validation listener is added too: one can see that several lines above.
I had a look at the source code of EclipseLink 2.3.3 and 2.4.0 and the problem seems to remain there as well.
Could anyone help me with that, please?
Re: Eclipselink 2.3.2 + composite persistence units + bean validation (jsr303) [message #909037 is a reply to message #905060] Thu, 06 September 2012 08:52 Go to previous message
James Sutherland is currently offline James Sutherland
Are you sure it does not work if you set it on the master persistence unit?
If you are not seeing it working, please log a bug.
James : Wiki : Book : Blog
Previous Topic:Proper EntityManger in multi-thread App
Next Topic:Suggestion: commit() method returning the number of committed.
Current Time: Sun May 19 07:01:28 EDT 2013
Powered by FUDForum. Page generated in 0.01610 seconds
