Home » Eclipse Projects » Memory Analyzer » Unable to Open Heap Dump
Unable to Open Heap Dump [message #908580] Wed, 05 September 2012 11:48 Go to next message
Mustafa Cayci is currently offline Mustafa Cayci
I installed OEPE
Oracle ADF Tools
Part of Oracle Enterprise Pack for Eclipse 11.1.1.7.2
Tools for developing applications using Oracle ADF.
Copyright (c) 2011 Oracle and/or its affiliates.
All rights reserved. Oracle is a registered trademark of
Oracle Corporation and/or its affiliates. Other names may
be trademarks of their respective owners.
It is using Eclipse platform
Eclipse Platform
Version: 3.6.2
Build id: M20110210-1200
I installed MAT
Eclipse Memory Analyzer - RCP feature
Version: 1.2.0.201205300858
Build id: 1.2.0
Whenever I click on the "Open Heap Dump" button on the Toolbar, I am seeing the following stack
java.lang.NoClassDefFoundError: org/eclipse/jface/wizard/IWizardPage
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.mat.ui.internal.acquire.AcquireSnapshotAction.run(AcquireSnapshotAction.java:81)
at org.eclipse.mat.ui.internal.acquire.AcquireSnapshotAction.run(AcquireSnapshotAction.java:245)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Would you please help me sort this one out? I need to analyze a heap dump.
Thank you,
Mustafa
Re: Unable to Open Heap Dump [message #908583 is a reply to message #908580] Wed, 05 September 2012 11:51 Go to previous messageGo to next message
Aurelien Pupier is currently offline Aurelien Pupier
did you install MAT inside your eclipse platform or are you using a standalone version?
If inside your eclipse, which version? Can you try with a standalone version of MAT? perhaps there is a conflict with another plugin.
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: Unable to Open Heap Dump [message #908597 is a reply to message #908583] Wed, 05 September 2012 12:15 Go to previous message
Thank you Aurelien.
Yes that worked. I will use standalone MAT from now on.
Thank you,
Mustafa
Previous Topic:Full memory usage
Next Topic:How to open previous results of analyze?
Current Time: Tue May 21 22:21:28 EDT 2013
Powered by FUDForum. Page generated in 0.02967 seconds
