Home » Newcomers » Newcomers » Eclipse C/C++ help, gcc not found.
Eclipse C/C++ help, gcc not found. [message #908235] Tue, 04 September 2012 21:51 Go to next message
Alex Gilbreath is currently offline Alex Gilbreath
I saw the 'before you begin' section where you have to install MinGW for Eclipse to work correctly (Eclipse Juno). Both my C++ test project and C project have the following errors:
Program "gcc" not found in PATH
sh -c "autoreconf -i"
and the C++ has the error
Program "g++" not found in PATH
Did I miss that you had to install something else? Did I have to manually add some PATH variable and I have no clue what the second error is saying. Can anyone tell me where I'm being stupid?
Windows 7 64-bit.
Re: Eclipse C/C++ help, gcc not found. [message #908498 is a reply to message #908235] Wed, 05 September 2012 09:30 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> Windows 7 64-bit.
Please read sticky posts at top of forum.
Re: Eclipse C/C++ help, gcc not found. [message #910796 is a reply to message #908498] Mon, 10 September 2012 08:05 Go to previous messageGo to next message
wone chen is currently offline wone chen
yes you shuold read more
Re: Eclipse C/C++ help, gcc not found. [message #917013 is a reply to message #908498] Wed, 19 September 2012 14:31 Go to previous messageGo to next message
josh schwartzbeck is currently offline josh schwartzbeck
Russell Bateman wrote on Wed, 05 September 2012 09:30
> Windows 7 64-bit.
This post is among the top google search results for this question and like many of the top google search results involving software development, the answers tell the asker to look somewhere else. The diligent asker will take the advice and look at the sticky posts at the top of the forum as such:
sticky: Trouble with Android Development Tools (ADT)? READ THIS FIRST
Not Applicable
sticky: Trouble getting Eclipse to run? READ THIS FIRST
Advises to install the latest or correct architecture of the JVM.
Not Applicable
Announcement: New forum members, READ THIS FIRST.
Mentions forum etiquette and that C/C++ developers should look at another sticky post:
Problems with C/C++ in Eclipse? Read this.
states that C/C++ developers are welcome to the newcomer group but might get more help asking in the cdt specific group: http://www.eclipse.org/forums/eclipse.tools.cdt
(no stickies here)
Announcement: Linux + Eclipse users, read this!
Not Applicable (Running Windows 7, per original post)
sticky: Problems with C/C++ in Eclipse? Read this.
same as above
After spending the time to read through all the stickies, the newcomer trying to get their C/C++ environment working in eclipse has been told several times to look and ask somewhere else, specifically the CDT forums which have no stickies or instructions to get your eclipse project to recognize your gcc/g++ (even if you have it installed and it's in your PATH).
My point is that it would be hugely beneficial to the developer community as a whole if we were more helpful to each other and consider that answering someone's question directly will help many, many other people as well.
In my case, I found that the toolchain is generated when the project is created and if you don't have the tools installed before hand, you need to manually configure your project's toolchain or re-create the project. If you don't have gcc/g++ on Windows you can use the recommended MinGW installer at sourceforge. This forum won't allow me to link externally to MinGW or I would.
Edit: See also: http://wiki.eclipse.org/CDT/User/FAQ#Are_there_complete_HowTos_for_setting_up_the_CDT.3F
[Updated on: Wed, 19 September 2012 14:40]
Report message to a moderator
Re: Eclipse C/C++ help, gcc not found. [message #917078 is a reply to message #917013] Wed, 19 September 2012 15:56 Go to previous message
>> for
>> and C
>> error
>> > Windows 7 64-bit.
> Quote:
> Not Applicable
> Quote:
> Not Applicable
> Quote:
> Quote:
> (no stickies here)
> Quote:
> Quote:
> same as above
> it's in your PATH).
> people as well.
The sticky about CDT at the top of this forum suggests you ask your
C/C++ question in the Eclipse CDT forum. It doesn't say there are more
stickies there.
The Eclipse CDT forum is a place, like the Eclipse newcomers forum,
where you ask a question and get it answered. In this case, lots of
Eclipse C/C++ users are there to help solve your problems, more than
haunt the newcomers' forum. It's not to put you off.
Previous Topic:Eclipse auto complete suggestions not working properly
Next Topic:Adobe Flash Builder plugin for eclipse
Current Time: Wed May 22 02:46:24 EDT 2013
Powered by FUDForum. Page generated in 0.09662 seconds
