Home » Newcomers » Newcomers » Syntax Coloring usability suggestion
Syntax Coloring usability suggestion [message #904555] Tue, 28 August 2012 13:19 Go to next message
p h is currently offline p h
When using 'Syntax Coloring', sometimes is tricky (for me at least) to find the item in the 'Element' list that corresponds to that purple stuff that needs to be green Wink
anyway, here's my suggestions to make the dialog a little easier to use:
1) make it so that when you click in the 'Preview' window it selects the corresponding item in the 'Element' list.
2) when scrolling up/down in the 'Element' list with the arrow keys, it takes about 1 second for the 'Color' swatch to fade between the colors. this makes finding a particular color swatch a somewhat slow process. making the swatch fade states immediately would be a help here.
Re: Syntax Coloring usability suggestion [message #904699 is a reply to message #904555] Tue, 28 August 2012 21:22 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
The XML/HTML/JSP/DTD/CSS Syntax Coloring preference pages already do this. Which language are you referring to? Regardless, all enhancement requests belong in Bugzilla: https://bugs.eclipse.org/bugs/enter_bug.cgi .
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Syntax Coloring usability suggestion [message #908118 is a reply to message #904699] Tue, 04 September 2012 15:10 Go to previous message
i guess any language that's not one of those, then, for example Java, Javascript, C/C++, Ant.
regardless, all these languages still suffer from the problem with the color swatch taking 1 second to animate between enabled/disabled states.
Previous Topic:Running PHP file give me "This program cannot display the webpage"
Next Topic:Cocoa SWT Not working?
Current Time: Fri May 24 14:57:56 EDT 2013
Powered by FUDForum. Page generated in 0.08624 seconds
