Home » Eclipse Projects » BIRT » apache.commons.io dependency problem(Report-engine libs include old commons.io version)
apache.commons.io dependency problem [message #905394] Thu, 30 August 2012 06:01 Go to next message
Peter Courcoux is currently offline Peter Courcoux
In the org.apache.batik.pdf_1.6.0.v201105071520.jar which is used by the report engine in both version 4.2 and 3.7 a number of commons.io classes are included.
If copying the contents of report-engine/lib folder to WEB-INF/lib these classes can mask classes from other commons-io jars included in a non-osgi web app.
In the specific case I am looking at, I am seeing a NoSuchMethodError relating to a missing IOUtils.copy(InputStream, Writer) method which was introduced in Commons.io version 1.1, indicating that the included classes are very old.
Questions:
Is there a reason why later versions of commons.io cannot be used?
If not, is it possible to update the offending batik jar to use a more recent version of commons.io, or better still remove those classes and provide a separate commons-io jar?
Who is responsible for packaging the batik jar? Is this an eclipse.birt issue or should I be asking elsewhere?
Re: apache.commons.io dependency problem [message #905620 is a reply to message #905394] Thu, 30 August 2012 14:56 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Peter
Can you open a bugzilla request for this?
Jason
> are included.
> non-osgi web app.
> Questions:
Jason Weathersby
BIRT Exchange
Re: apache.commons.io dependency problem [message #905649 is a reply to message #905394] Thu, 30 August 2012 16:04 Go to previous messageGo to next message
Hi Jason.
Yes, I will post a Bugzilla request.
Peter
Re: apache.commons.io dependency problem [message #906109 is a reply to message #905649] Fri, 31 August 2012 12:26 Go to previous messageGo to next message
Thanks Peter
On 8/30/2012 4:04 PM, Peter Courcoux wrote:
> Hi Jason.
> Peter
Jason Weathersby
BIRT Exchange
Re: apache.commons.io dependency problem [message #906493 is a reply to message #906109] Sat, 01 September 2012 13:02 Go to previous messageGo to next message
Jason,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388514
Peter
Re: apache.commons.io dependency problem [message #908012 is a reply to message #906493] Tue, 04 September 2012 10:41 Go to previous message
Peter,
Will you be able to post the bug to the Orbit project?
Jason
On 9/1/2012 1:02 PM, Peter Courcoux wrote:
> Jason,
> Peter
Jason Weathersby
BIRT Exchange
Previous Topic:Calculates with 2 Data Sets
Next Topic:Applet jar requirements for BIRT (4.2) ReportEngine
Current Time: Wed May 22 21:30:43 EDT 2013
Powered by FUDForum. Page generated in 0.19099 seconds
