Home » Eclipse Projects » BIRT » [delete me]
[delete me] [message #907815] Tue, 04 September 2012 05:18 Go to next message
David B. is currently offline David B.
I'm using BIRT 3.7.1 and I have some issues when exporting to DOC format:
- The hyperlinks and bookmarks don't work correctly, however they are working fine with PDF export. The link is correct but the bookmark is not created in the DOC file, so when I click on the link it goes nowhere in the document.
- I have trouble with the crosstab layout: in the PDF export it looks OK but in the DOC export, the crosstab layout is very bad. I am using the auto layout because the number of columns is variable.
I attached a Java project with a report example showing both of my issues.
Maybe I did something wrong in the report but I think it may be some configuration problem in the code calling the report generation, since the PDF export works pretty well.
Thanks in advance for your help!
David
[Updated on: Tue, 04 September 2012 12:30]
Report message to a moderator
Re: DOC export issue with Hyperlinks and Crosstabs [message #907951 is a reply to message #907815] Tue, 04 September 2012 09:36 Go to previous message
Oops. Additional question: how can I delete the many duplicates for this topic? (there was a bug on the forum, the topic didn't seem to be created so I tried again and again...)
Edit: I couldn't find any way to delete the duplicates so I renamed them to [delete me] so a moderator can detect them easily.
[Updated on: Tue, 04 September 2012 10:32]
Previous Topic:[delete me]
Next Topic:problem in binding data source to a table from BIRT library
Current Time: Sat May 25 19:32:46 EDT 2013
Powered by FUDForum. Page generated in 0.01639 seconds
