Home » Eclipse Projects » Remote Application Platform (RAP) » [New Target Problem] Custom Theming of CTabFolder(Problem with CTabItem:selected)
[New Target Problem] Custom Theming of CTabFolder [message #907211] Mon, 03 September 2012 10:34 Go to next message
Francis Delsinnes is currently offline Francis Delsinnes
Member
I've got a problem with my css file to custom the display of CTabFolder.
I speak about "TabFolder" from Views into a RAP Perspective.
The theme for "CTabItem:selected" doesn't work with RAP Targets 1.5.0-M7 and 2.0.0-M1!?
Remarks; the same theme works into the RAP Target 1.5.0M2
Here is my css (part):
CTabItem {
	font: bold 12px sans-serif;         /* WORKS */
	color: gray;                        /* WORKS */
	background-color: transparent;      /* WITH A COLOR, DOESN'T WORK !!! */
	background-image: none;             /* WORKS */
	padding: 5px;                       /* WORKS */
	spacing: 0px;                       /* WORKS */
	text-shadow: none;                  /* WORKS */
CTabItem:selected {
	color: white;                       /* DOESN'T WORK */
	background-color: #4282AD;          /* DOESN'T WORK */
	background-image: gradient(         /* DOESN'T WORK */
    	linear, left top, left bottom,
    	from( black ),
    	color-stop( 52%, black ),
    	color-stop( 48%, #4282AD ),
    	to( #4282AD )
I need help / ideas
Thanks in advance
Re: [New Target Problem] Custom Theming of CTabFolder [message #907929 is a reply to message #907211] Tue, 04 September 2012 07:05 Go to previous messageGo to next message
Tim Buschtoens is currently offline Tim Buschtoens
Hi.
It seems to work fine for me. What is displayed instead of the values
you give? (E.g. when the item is selected, what color is the text, if
its not white?) Also, is this part of a complete theme or a
contribution? How do you register it?
Greetings,
Tim
Am 03.09.2012 16:34, schrieb Francis Delsinnes:
> and 2.0.0-M1!?
> CTabItem {
> CTabItem:selected {
> from( black ),
> to( #4282AD )
> I need help / ideas
> Thanks in advance
Tim Buschtöns
Twitter: @EclipseRAP
Re: [New Target Problem] Custom Theming of CTabFolder [message #907962 is a reply to message #907929] Tue, 04 September 2012 09:45 Go to previous messageGo to next message
Member
Currently:
the text color of my selected tab is not "white" but "black"...
the background of my selected tab is a gradient between light-blue and mid-blue (not my gradient)
I've defined an extension into the MANIFEST (plugin.xml)
=> "org.eclipse.rap.ui.themes"
with a css file
with an Id and a string name
I've configured the extension "org.eclipse.rap.ui.branding" to use my theme's Id.
Actually, all css are fine computed for RWT controls but for the specific part of the RAP workbench (CTabFolder, CTabItem), it doesn't work!
Here is the content of my customTheme.css file
ProgressBar {
	background-color: white;
	border: 1px solid #74808C;
ProgressBar-Indicator {
Button[PUSH], Button[TOGGLE], Button[RADIO] {
	color: #262626;
    	from( #FFFFFF ),
    	color-stop( 48%, #FEFEFE ),
    	color-stop( 52%, #FEFEFF ),
    	to( #BDC5D9 )
Button[PUSH]:hover, Button[TOGGLE]:hover, Button[RADIO]:hover {
	border: 1px solid #BDC5D9;
	color: #4282AD;
    	from( #BDC5D9 ),
    	to( #FFFFFF )
Button[FLAT] {
	border: none;
	color: transparent;
Button[FLAT]:hover {
	border: none;
	color: transparent;
    	from( #BDC5D9 ),
    	to( #FFFFFF )
Button[PUSH]:disabled, Button[TOGGLE]:disabled, Button[FLAT]:disabled, Button[RADIO]:disabled {
	color: #74808C;
Composite {
	animation: none;
	border: none;
	box-shadow: none;
	opacity: 1;
  	padding: 0px;
Composite[BORDER] {
	border: none;
    	from( #4282AD ),
    	color-stop( 20%, #4282AD ),
    	color-stop( 80%, black ),
    	to( black )
  	padding: 0px;
  	spacing: 0px;
DateTime {
	border: none;
	color: #262626;
DateTime-Calendar-Day:hover {
	border: none;
	color: #FFFFFF;
DateTime-Calendar-Day:selected {
	background-color: #FAB75F;
	color: #525252;
DateTime-Calendar-Navbar {
	border: 1px solid #5FBCFA;
	color: #FFFFFF;
DateTime-Calendar-Navbar:disabled {
	border: 1px solid #5F5F5F;
	background-color: #424242;
	color: #FFFFFF;
Combo, CCombo {
	border: none;
Combo-Field, CCombo-Field {
	padding: 2px;
Combo-List, CCombo-List {
	border: none;
	box-shadow: 0px 0px 5px rgba( 84, 136, 48, 0.85 );
Combo-FocusIndicator, CCombo-FocusIndicator {
	margin: 0px 0px 0px 0px;
Combo-Button-Icon, CCombo-Button-Icon {
	background-image: url( icons/comboButton.png );
Menu {
	border: 2px solid #5FBCFA;
	border-radius: 5px;
	box-shadow: 0px 0px 10px rgba( 95, 188, 250, 0.85 );
	opacity: 1;
MenuItem:hover {
	background-color: #7aaed1;
	color: black;
Shell-Titlebar {
	color: white;
    	from( black ),
    	to( #4282AD )
Shell, Shell:inactive {
	border: 2px solid black;
	border-radius: 5px;
	box-shadow: 0px 0px 5px rgba( 0, 0, 0, 0.45 );
Shell:maximized {
	border: none;
	box-shadow: 0px 0px transparent;
Shell[SHEET] {
	border: none;
Widget-ToolTip {
	color: #646464;
	box-shadow: 0px 0px 10px rgba( 95, 188, 250, 0.45 );
Table {
	border: 1px solid gray;
	color: black;
Table-GridLine:horizontal {
	color: #74808C;
Table-GridLine:vertical {
	color: #4282AD;
TableColumn {
    	from( #4282AD ),
    	color-stop( 48%, black ),
    	to( black )
	color: white;
	padding: 5px;
TableColumn:hover {
    	from( #7aaed1 ),
    	color-stop( 52%, #7aaed1 ),
    	color-stop( 48%, #7aaed1 ),
    	to( white )
	color: black;
	padding: 5px;
TableItem:even {
	background-color: #d5dfe6;
TableItem:selected {
	background-color: #7d8d99;
	color: white;
TableItem:hover {
	color: black;
TableItem:selected:hover {
	background-color: #597f99;
	color: white;
Table-Cell {
	padding: 1px;
	spacing: 0px;
Label, Label[BORDER] {
	border: none;
Label[BORDER] {
	color: white;
Text {
	padding: 0px;
Text[MULTI] {
	padding: 10px;
Sash {
	border: none;
ExpandBar {
	border: none;
	color: white;
ExpandItem {
	border: none;
ExpandItem-Header {
	border: none;
    	from( #4282AD ),
    	color-stop( 80%, #424242 ),
    	to( #424242 )
ExpandItem-Header:expanded {
	border: none;
    	from( #7aaed1 ),
    	to( white )
ExpandItem-Button {
	background-image: url( icons/noexpanded.png );
ExpandItem-Button:hover {
	background-image: url( icons/noexpandedHover.png );
ExpandItem-Button:expanded {
	background-image: url( icons/expanded.png );
ExpandItem-Button:expanded:hover {
	background-image: url( icons/expandedHover.png );
Group {
	border: none;
	font: bold 13px sans-serif;
Group-Frame {
	border: 1px solid #805a20;
	border-radius: 5px;
	margin: 15px 0px 0px 0px;
	padding: 10px 2px 2px 2px;
Group-Label {
	border: 1px solid #d99936;
	border-radius: 2px;
	padding: 2px 5px 2px 5px;
ScrollBar[VERTICAL] {
    	linear, left top, right top,
    	from( #d5dfe6 ),
    	color-stop( 5%, white ),
    	to( #d5dfe6 )
	border: none;
	width: 16px;
ScrollBar[HORIZONTAL] {
    	from( #d5dfe6 ),
    	to( #d5dfe6 )
	border: none;
	width: 16px;
ScrollBar-Thumb[VERTICAL] {
    	from( #d5dfe6 ),
    	color-stop( 20%, #d5dfe6 ),
    	color-stop( 80%, white ),
    	to( white )
	border: 1px solid #7d8d99;
ScrollBar-Thumb[HORIZONTAL] {
    	from( #d5dfe6 ),
    	to( white )
ScrollBar-UpButton, ScrollBar-DownButton {
	cursor: pointer;
ScrollBar-UpButton[VERTICAL] {
	background-image: url( icons/scrollDown.png );
ScrollBar-DownButton[VERTICAL] {
	background-image: url( icons/scrollUp.png );
ScrollBar-UpButton[HORIZONTAL] {
	background-image: url( icons/scrollRight.png );
ScrollBar-DownButton[HORIZONTAL] {
	background-image: url( icons/scrollLeft.png );
ToolBar, ToolBar[BORDER] {
    	from( #4282AD ),
    	to( black )
	border: none;
	color: white;
	opacity: 1;
	padding: 0px;
  	spacing: 0px;
ToolItem {
	animation: none;
	border: none;
	color: white;
	opacity: 1;
ToolItem:hover {
	border: none;
    	from( #7aaed1 ),
    	to( white )
  	color: black;
ToolItem-DropDownIcon {
	background-image: url(icons/down.png);
	border: none;
ToolItem-Separator {
	width: 0px;
CTabFolder {
	border-color: white;
	border-radius: 5px;
CTabItem {
	color: gray;
	padding: 10px;
	spacing: 10px;
CTabItem:selected {
	color: white;
    	from( black ),
    	to( #4282AD )
CoolItem-Handle {
	border: none;
	width: 0px;
Thanks for your response.
Re: [New Target Problem] Custom Theming of CTabFolder [message #907965 is a reply to message #907929] Tue, 04 September 2012 09:47 Go to previous messageGo to next message
Member
... double post ... (sorry)
[Updated on: Thu, 06 September 2012 04:03]
Report message to a moderator
Re: [New Target Problem] Custom Theming of CTabFolder [message #907966 is a reply to message #907929] Tue, 04 September 2012 09:48 Go to previous messageGo to next message
Member
[Updated on: Thu, 06 September 2012 04:06]
Re: [New Target Problem] Custom Theming of CTabFolder [message #907975 is a reply to message #907211] Tue, 04 September 2012 09:51 Go to previous messageGo to next message
Member
[Updated on: Thu, 06 September 2012 04:09]
Re: [New Target Problem] Custom Theming of CTabFolder [message #907986 is a reply to message #907211] Tue, 04 September 2012 09:59 Go to previous messageGo to next message
Member
If you need the registration, see the two last extensions from my plugin.xml file:
<?eclipse version="3.4"?>
<plugin>
   <extension
         id="viewapp"
         point="org.eclipse.core.runtime.applications">
      <application
            thread="main"
            cardinality="singleton-global"
            visible="true">
         <run
               class="test.process.client.explorer.Application">
         </run>
      </application>
   </extension>
   <extension
         point="org.eclipse.ui.perspectives">
      <perspective
            name="RAP Perspective"
            class="test.process.client.explorer.Perspective"
            id="ActivitiRapExplorer.perspective">
      </perspective>
   </extension>
   <extension
         point="org.eclipse.ui.views">
      <view
            allowMultiple="false"
            class="test.process.client.explorer.MyInstancesView"
            id="ActivitiRapExplorer.MyInstancesView"
            name="My Instances"
            restorable="true">
      </view>
      <view
            class="test.process.client.explorer.MyProcessesView"
            id="ActivitiRapExplorer.MyProcessesView"
            name="My Processes"
            restorable="true">
      </view>
   </extension>
   <extension
         point="org.eclipse.rap.ui.branding">
      <branding
            servletName="bpmExplorer"
            themeId="test.process.client.explorer.customTheme"
            defaultEntrypointId="ActivitiRapExplorer.viewapp"
            title="Activiti Rap Explorer"
            id="test.process.client.explorer.branding">
      </branding>
   </extension>
   <extension
         point="org.eclipse.rap.ui.themes">
      <theme
            file="css/customTheme.css"
            id="test.process.client.explorer.customTheme"
            name="Custom Theme">
      </theme>
   </extension>
</plugin>
Re: [New Target Problem] Custom Theming of CTabFolder [message #908416 is a reply to message #907211] Wed, 05 September 2012 06:46 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi Francis,
Workbench has its own default theme (completely different from RWT)
witch is defined in the org.eclipse.rap.ui\plugin.xml file (see
org.eclipse.ui.themes extension point). The values from the the
workbench theme is set by the Java code. In RAP all properties set by
the code override the properties set by the RWT theme... or in other
words... the properties set by the Workbench theme override the
properties set by the RWT theme. In your case this is valid for CTabItem
selection foreground color, background color and background gradient
(see Workbench theme properties like
org.eclipse.ui.workbench.ACTIVE_TAB_TEXT_COLOR,
org.eclipse.ui.workbench.ACTIVE_TAB_BG_END...).
HTH,
Ivan
> CTabItem {
> CTabItem:selected {
> background-image: gradient( /* DOESN'T WORK */ linear,
> from( black ),
> to( #4282AD )
> I need help / ideas
> Thanks in advance
Ivan Furnadjiev
Re: [New Target Problem] Custom Theming of CTabFolder [message #908906 is a reply to message #908416] Thu, 06 September 2012 04:00 Go to previous messageGo to next message
Member
Thanks for your information.
=> Now, I set custom colors for the workbench directly by code.
Into the ApplicationWorkbenchWindowAdvisor class
Method: @Override public void preWindowOpen() { ... }
after the settings of IWorkbenchWindowConfigurer object.
Remark: with the previous versions of RAP targets, the css theme was also applied to the Workbench Parts like the Views.
Re: [New Target Problem] Custom Theming of CTabFolder [message #908923 is a reply to message #908416] Thu, 06 September 2012 04:27 Go to previous messageGo to next message
Hi Francis,
Which versions exactly? I'm not aware of any change in this direction.
Best,
Ivan
On 9/5/2012 1:46 PM, Ivan Furnadjiev wrote:
> Hi Francis,
> CTabItem selection foreground color, background color and background
> gradient (see Workbench theme properties like
> HTH,
> Ivan
>> CTabItem {
>> CTabItem:selected {
>> from( black ),
>> to( #4282AD )
>> I need help / ideas
>> Thanks in advance
Ivan Furnadjiev
Re: [New Target Problem] Custom Theming of CTabFolder [message #908957 is a reply to message #908923] Thu, 06 September 2012 05:52 Go to previous messageGo to next message
Member
About RAP Targets and CSS theme applied to Workbench Parts:
An example: fonts and colors for CTabItem (applied to Views of perspectives)
1.4.0, 1.4.1
CTabItem {
	font
	color
	background-color
1.5.0 Release
CTabItem {
	color
1.5.0-M2
CTabItem {
	font
	color
	background-color
1.5.0-M3, 1.5.0-M4, 1.5.0-M5, 1.5.0-M6, 1.5.0-M7, 2.0.0-M1
CTabItem {
	color
Re: [New Target Problem] Custom Theming of CTabFolder [message #990971 is a reply to message #908957] Sat, 15 December 2012 13:56 Go to previous message
Wim Anckaert is currently offline Wim Anckaert
Francis,
I have the same problem with styling the CTabFolder.
Can you explain me what you changed colors on that workbench?
Tx,
Wim
Previous Topic:Tycho running integration-test despite servletbridge-bug?
Next Topic:view on the action open a dialog, feasibility?
Current Time: Sun May 26 02:08:01 EDT 2013
Powered by FUDForum. Page generated in 0.02620 seconds
