Home » Eclipse Projects » Rich Client Platform (RCP) » Welcome Page Ubuntu
Welcome Page Ubuntu [message #906839] Sun, 02 September 2012 14:35 Go to next message
Sir Wayne is currently offline Sir Wayne
the eclipse welcome page on my ubuntu is shown correctly, but when i start my rcp the welcome page is white and empty - no exception, no error message.
On Windows the welcome page works correctly.
Has anybody an idea?
<extension
         point="org.eclipse.ui.intro.config">
      <config
            content="introContent.xml"
            id="blutmessung.ui.introConfigId"
            introId="blutmessung.ui.intro">
         <presentation
               home-page-id="root">
            <implementation
                  kind="html">
            </implementation>
         </presentation>
      </config>
   </extension>
Re: Welcome Page Ubuntu [message #909172 is a reply to message #906839] Thu, 06 September 2012 13:09 Go to previous messageGo to next message
Has nobody an idea?
Re: Welcome Page Ubuntu [message #910834 is a reply to message #909172] Mon, 10 September 2012 09:23 Go to previous messageGo to next message
Hamed Mohammadi is currently offline Hamed Mohammadi
Member
I had the same problem and few other problems in ubuntu. Now I'm using Fedora 17.
Re: Welcome Page Ubuntu [message #910877 is a reply to message #909172] Mon, 10 September 2012 10:51 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
My guess is that the Browser widget is not working in the context of
your RCP app. Do you have some setting in your dev environment that is
helping it to run there (eg.- setting a java property to point at a
native browser, etc.)? And which Ubuntu and Eclipse/SWT version are you
using?
Grant
On 9/6/2012 1:09 PM, Sir Wayne wrote:
> Has nobody an idea?
Re: Welcome Page Ubuntu [message #910967 is a reply to message #910877] Mon, 10 September 2012 14:08 Go to previous messageGo to next message
Grant Gayed wrote on Mon, 10 September 2012 10:51
using?
Grant
Why do i need "special" setup on my environment?
Because my eclipse IDE welcome page on the same environment works well. So my opnion is eclispe does it on a different way or sets a special setup? What's the difference?
Re: Welcome Page Ubuntu [message #911884 is a reply to message #910967] Wed, 12 September 2012 10:01 Go to previous messageGo to next message
You should not need anything special to run in your dev environment vs.
running as an RCP app, but since these are behaving differently for you
on the same machine I was wondering if you had done something to get it
working in your dev environment that you had forgotten about.
To determine whether it is in fact a Browser issue, can you make a small
change to your app to show a Browser somewhere that's pointing at any
URL, and see if it also works in your dev environment and fails in your
RCP app?
Grant
>> is helping it to run there (eg.- setting a java property to point at a
>> you using?
>> Grant
Re: Welcome Page Ubuntu [message #911932 is a reply to message #906839] Wed, 12 September 2012 11:52 Go to previous message
Libor Jelinek is currently offline Libor Jelinek
Search for this issue in Eclipse Bugzilla. If I remember correctly, it
was recently reported by a couple of Ubuntu users.
Libor
On 09/02/2012 08:35 PM, Sir Wayne wrote:
> Hello,
> error message. On Windows the welcome page works correctly. Has anybody
> an idea?
> <extension
> <config
> <presentation
> <implementation
> kind="html">
> </implementation>
> </presentation>
> </config>
> </extension>
Previous Topic:Need help with builder
Next Topic:Are there any guidelines availble for dual mode plugins
Current Time: Sat May 18 08:21:57 EDT 2013
Powered by FUDForum. Page generated in 0.02760 seconds
