| Check a table has no rows? [message #906020] |
Fri, 31 August 2012 09:26  |
Erik Gilbert Messages: 55 Registered: September 2010 |
Member |
I used ub_tbl_checkTextWithCellSpec to verify rows in a table. Is there a way to verify that there are no rows in a table? Perhaps with ub_tbl_checkTextWithCellSpec?
| Re: Check a table has no rows? [message #915937 is a reply to message #909059] |
Tue, 18 September 2012 04:49   |
Member |
I tried rowCount, Row Count, Count, and count. But they don't seem to work. I also looked through the Jubula source code. rowCount seems to be the correct property but when I use it, I get the error message :
Test Result
Status : Step failed
Error Details
Type : Action Error
Error Description : Property not Accessible
Component Details
Component Name : search results table Textcode pane
Component Type : Graphics Component
Action Type : Check Property
Test Data
Property Name : rowCount
Property Value : 0
Operator : equals
If rowCount is the correct property, I wonder if there is some other reason why it is not accessible?
[Updated on: Tue, 18 September 2012 04:49] Report message to a moderator
FUDForum. Page generated in 0.01883 seconds
