Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EEF] Errors in the generated code.
| [EEF] Errors in the generated code. [message #905939] |
Fri, 31 August 2012 06:43  |
aurelien didier Messages: 11 Registered: June 2012 |
Junior Member |
Hi everybody,
I have some errors in the eef generated code, and I don't know how to solve them.
In a package called: ClassPropertiesEditionComponent, I have:
public void initPart(Object key, int kind, EObject elt, ResourceSet allResource) {
setInitializing(true);
if (editingPart != null && key == partKey) {
editingPart.setContext(elt, allResource);
final Class class_ = (Class)elt;
The problem highlighted by eclipse is that: I Cannot cast from EObject to Class
So I try to do that: final EObject class_=(EObject)elt;
But then I have many other mistake that appears (they can be corrected easily). So I was wondering if it is the right thing to do.
Plus, I have an other error in the EEF generated code,
In the package RealTimeProperties.RtpMeasurementUnits.providers, I have:
import RealTimeProperties.RtpMeasurementUnits.util.RtpMeasurementUnitsAdapterFactory;
public class RtpMeasurementUnitsEEFAdapterFactory extends RtpMeasurementUnitsAdapterFactory {
Here the code generation of EMF doesn't create the RealTimeProperties.RtpMeasurementUnits.util and EEF is trying to use it so the class RtpMeasurementUnitsAdapterFactory doesn't exist. (In my ecore model, the RtpMeasurementUnits are composed of enumeration types only).
And when I try to launch with correcting the first error and with deleting my RealTimleProperties.RtpMeasurementUnits.providers and the .parts also. I can create my global model and his child (with obeo designer), but when I use one of his child,I have an error like:
"An error has occurred. See error log for more details.
The string resource '_UI_EPackage_eSubpackages_feature' could not be located"
Any help would be great.
Aurélien.
| Re: [EEF] Errors in the generated code. [message #907166 is a reply to message #905939] |
Mon, 03 September 2012 08:40   |
Goulwen Le Fur Messages: 115 Registered: July 2009 |
Hi Aurélien,
Many problems in your mail :)
Le 31/08/2012 12:43, aurelien didier a écrit :
> Hi everybody,
> solve them.
> allResource) {
> to Class
First, I think that this issue is due to a bad import organized. I think
your metamodel has a concept named "Class" and during imports
organization, you java.lang.Class has been added to the imports list
instead of your.metamodel.Class.
> import
> only).
I think there is a good reason why EMF doesn't generate an
AdapterFactory for the RtpMeasurementUnits package of your model but I
can't figure why? Can you give more information about this package ?
> located"
This issue is due to an ResourceLocator error ... Once again I haven't
got enough clue to fix it. What about your MetamodelEditPlugin class ?
Do you have a link to the Ecore edit plugin ?
Goulwen
> Aurélien.
| Re: [EEF] Errors in the generated code. [message #908044 is a reply to message #907166] |
Tue, 04 September 2012 11:41   |
Junior Member |
Hi Goulwen,
Thank you for your answer, at the first question, I'll try to correct that.
For the second one, EMF doesn't generate the ***.util because in the ecore model, this package is only composed of enumeration types, as you can see in my attachment.
If I want to use EEF, do I have to change my model, by defining my enumeration type apart, and to define attributes which are instance of one of my enumeration type. Or is it posible to keep my ecore model as it is now.
And for the third error, I think that it was link to one of the other error, but in fact, I'm not working alone on that project, and this error is not due to my work, but to something uncomplete. Sorry.
Aurélien.
Current Time: Tue May 21 23:05:42 EDT 2013
Powered by FUDForum. Page generated in 0.10703 seconds
