Home » Eclipse Projects » JFace » ObservableMap binding to a Combo
ObservableMap binding to a Combo [message #902939] Tue, 21 August 2012 06:32 Go to next message
Daniel McGreal is currently offline Daniel McGreal
I would like to bind an ObservableMap to a Combo. I currently have code which binds an ObservableSet:
WritableSet selectedSet = new WritableSet(SWTObservables.getRealm(RedMobileControl.getDisplay()));
ComboViewer selectedViewer = new ComboViewer(this, SWT.READ_ONLY | SWT.DROP_DOWN);
selectedViewer.setContentProvider(new ObservableSetContentProvider());
selectedViewer.setInput(selectedSet);
selectedViewer.setLabelProvider(new LabelProvider(){
	@Override public String getText(Object element) {
		//Some irrelevant code here.
The problem is that I would like the set to have a nice fast lookup key for use elsewhere in the application (I don't care whether I have access to the key in the LabelProvider for example) and there is no ObservableMapContentProvider. Any ideas how I can achieve this binding?
Many thanks,
Dan.
Re: ObservableMap binding to a Combo [message #904441 is a reply to message #902939] Tue, 28 August 2012 08:34 Go to previous messageGo to next message
So there is no easy way to achieve this? Any hard ways? Smile
Thanks, Dan.
Re: ObservableMap binding to a Combo [message #904851 is a reply to message #904441] Wed, 29 August 2012 05:15 Go to previous messageGo to next message
Marco Maccaferri is currently offline Marco Maccaferri
On 28/08/2012 14:34 Daniel McGreal ha scritto:
> So there is no easy way to achieve this? Any hard ways? :)
Use a WritableList as input to the combo, then add a IMapChangeListener
to the map and update the list with the content differences.
Marco.
Re: ObservableMap binding to a Combo [message #905929 is a reply to message #904851] Fri, 31 August 2012 06:21 Go to previous message
Marco Maccaferri wrote on Wed, 29 August 2012 05:15
Marco.
Thanks. That's the approach I've ended up using, but the duplication is not so neat as being able to use a map directly input to the combo.
Previous Topic:TreeViewer with multiple same objects,adds child to first occurence of its parent
Next Topic:Customizing content assistant
Current Time: Fri May 24 23:27:14 EDT 2013
Powered by FUDForum. Page generated in 0.04078 seconds
