Home » Eclipse Projects » XML Schema Definition (XSD) » one XML element value as other xml element value(XML element value)
icon5.gif  one XML element value as other xml element value [message #905904] Fri, 31 August 2012 05:36 Go to next message
bala ganapathi is currently offline bala ganapathi
Hi All,
Am having an XML file which looks like the following,
<param-attribute>
<attribute-name>Activate</attribute-name>
</param-attribute>
<param-attribute>
<attribute-name>De-Activate</attribute-name>
</param-attribute>
<Service>
<action>
<param>Activate</param>
<param>De-Activate</param>
</action>
</Service>
Here the <param> element value "Activate" which is a value of element <attribute-name>
How to ensure in XSD, the <param> element value can be value of any one of <attribute-name> element value?
Please help me on writing .XSD for this validation.
Eagarly awaiting for response from XSD gurus ...
Balagan.
Re: one XML element value as other xml element value [message #905914 is a reply to message #905904] Fri, 31 August 2012 05:51 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Balagan,
You might be able to so something like that with keyref, but I'm not
sure how. This forum isn't intended for general help writing XML
Schemas but rather specific help for using Eclipse's XSD API to read,
write, and analyze schemas programmatically.
On 31/08/2012 11:36 AM, bala ganapathi wrote:
> Hi All,
> <param-attribute>
> </param-attribute>
> <param-attribute>
> </param-attribute>
> <Service>
> <action>
> </action>
> </Service>
> <attribute-name>
> Balagan.
Re: one XML element value as other xml element value [message #905919 is a reply to message #905914] Fri, 31 August 2012 06:03 Go to previous messageGo to next message
Thanks for your reply ED
Could you suggest some best reference site for writing .xsd
Balagan.
Re: one XML element value as other xml element value [message #905951 is a reply to message #905919] Fri, 31 August 2012 07:00 Go to previous message
I'm not sure. I personally only focused on the specification when
implement it. I'd have to Google to answer your question and you can do
that as well as me.
On 31/08/2012 12:03 PM, bala ganapathi wrote:
> Thanks for your reply ED Could you suggest some best reference site
> for writing .xsd
> Balagan.
Previous Topic:How to generate XSD from XML, by restricting all the values ?
Next Topic:Schema default value not honored for complex type
Current Time: Fri May 24 22:20:28 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
