Home » Eclipse Projects » Rich Client Platform (RCP) » Export wizard failing
Export wizard failing [message #899872] Thu, 02 August 2012 12:51 Go to next message
Valerio Santinelli is currently offline Valerio Santinelli
Member
I'm trying to export my 3.x RCP application that is now running under 4.2 with the compatibility layer but I stumbled upon an issue that I can't resolve.. when exporting through the wizard I get the error:
Unable to find feature "org.eclipse.e4.rcp" with version in range [1.1.0.v20120521-2329-8yFTIGF3GGduEYqkQB9M3DKn,1.1.0.v20120521-2329-8yFTIGF3GGduEYqkQB9M3DKn].
You can see it in the attachment.
index.php/fa/10990/0/
For some reason, when I click on the Required.. button on the dependencies tab, the org.eclipse.e4.rcp seems like broken.
index.php/fa/10991/0/
index.php/fa/10992/0/
What could I do?
Thanks!
Re: Export wizard failing [message #899900 is a reply to message #899872] Thu, 02 August 2012 14:14 Go to previous messageGo to next message
John Steele is currently offline John Steele
Member
What happens when you remove it from the dependencies and then re-add it?
Re: Export wizard failing [message #899904 is a reply to message #899900] Thu, 02 August 2012 14:34 Go to previous messageGo to next message
Member
I tried and it has the same behavior. Same error and same red cross on o.e.e4.rcp
Re: Export wizard failing [message #900013 is a reply to message #899904] Fri, 03 August 2012 09:00 Go to previous messageGo to next message
Member
I tried switching the product to plug-in based instead of feature based and now it's exporting it.
Why isn't the feature-based one working? I always used that before 4.2
Re: Export wizard failing [message #905895 is a reply to message #900013] Fri, 31 August 2012 05:17 Go to previous message
Member
I'm still trying to find a solution to this problem. Is o.e.e4.rcp actually needed when my RCP application is based on 3.x and I haven't done anything to port it to the 4.x framework? I don't get why Eclipse wants to add that feature to my dependencies..
Previous Topic:Loading a plugin programmatically
Next Topic:Common Navigator PluginTransfer DND
Current Time: Tue May 21 07:48:37 EDT 2013
Powered by FUDForum. Page generated in 0.01700 seconds
