Home » Eclipse Projects » scout » Smartfield - Key Shortcut for Browse New
Smartfield - Key Shortcut for Browse New [message #902068] Wed, 15 August 2012 13:47 Go to next message
Adrian Moser
Member
I am using getConfiguredBrowseNewText() and execBrowseNew(String searchText) on a Smartfield. This displays the "New" link as desired:
index.php/fa/11198/0/
How do I create a key shortcut for this link? Simply adding a key stroke to the smartfield doesn't seem to work when the proposal form is open.
Re: Smartfield - Key Shortcut for Browse New [message #903842 is a reply to message #902068] Sun, 26 August 2012 05:49 Go to previous messageGo to next message
Adrian Moser
Member
By overriding
protected ISmartFieldProposalForm createProposalForm() throws ProcessingException;
and patching the New Button to IButton.DISPLAY_STYLE_DEFAULT
import org.eclipse.scout.commons.exception.ProcessingException;
import org.eclipse.scout.rt.client.ui.form.fields.button.IButton;
import org.eclipse.scout.rt.client.ui.form.fields.smartfield.ISmartField;
import org.eclipse.scout.rt.client.ui.form.fields.smartfield.SmartTableForm;
public class KeyStrokeSmartTableForm extends SmartTableForm {
  public KeyStrokeSmartTableForm(ISmartField<?> smartField) throws ProcessingException {
    super(smartField);
  protected void execInitForm() throws ProcessingException {
    super.execInitForm();
    getNewButton().setDisplayStyleInternal(IButton.DISPLAY_STYLE_DEFAULT);
it is at least possible to use button mnemonics to execute the button using the keyboard.
However, it would be great to use f-keys as well without replacing the whole SmartTableForm.
Re: Smartfield - Key Shortcut for Browse New [message #904047 is a reply to message #903842] Mon, 27 August 2012 12:14 Go to previous messageGo to next message
Stephan Merkli is currently offline Stephan Merkli
Hi Adrian
Defining a key stroke for the browse new link does not seems to be supported yet. I tried it with adding a class of AbstractKeyStroke to the SmartTableForm, but with no success either.
The approach we usually use is to define a new menu on the smartfield (which supports key strokes).
      @Order(10.0)
      public class SectorField extends AbstractSmartField<Long> {
        protected String getConfiguredLabel() {
          return TEXTS.get("Sector");
        protected Class<? extends LookupCall> getConfiguredLookupCall() {
          return CompanySectorLookupCall.class;
        @Order(10.0)
        public class NewSectorMenu extends AbstractMenu {
          protected String getConfiguredText() {
            return TEXTS.get("NewSector_");
          protected boolean getConfiguredEmptySpaceAction() {
            return true;
          protected void execAction() throws ProcessingException {
            newAction();
          protected String getConfiguredKeyStroke() {
            return "F3";
        private void newAction() {
          // add desired action here
        public class F3KeyStroke extends AbstractKeyStroke {
            return "F3";
            newAction();
Stephan
Re: Smartfield - Key Shortcut for Browse New [message #904327 is a reply to message #904047] Tue, 28 August 2012 04:49 Go to previous messageGo to next message
Adrian Moser
Member
Thanks for your suggestion, Stephan.
But the key stroke action of the menu is not executed when the proposal form is open.
What I want, is a user-friendly way to add new entries to a smartfield:
- user types a 'ABC'
- smartfield proposal form opens, 'ABC' is not found
- when the value is not available, the user should be able to press a key shortcut and open a form to create the new entry with 'ABC' prefilled
Re: Smartfield - Key Shortcut for Browse New [message #905573 is a reply to message #904327] Thu, 30 August 2012 12:55 Go to previous messageGo to next message
Hi Adrian
This does not seem to be possible right now. What you need is something like a getConfiguredBrowseNewKeyStroke method on AbstractSmartField, am I right? Can you create a bugzilla ticket for this.
Thanks!
Stephan
Re: Smartfield - Key Shortcut for Browse New [message #905837 is a reply to message #902068] Fri, 31 August 2012 03:13 Go to previous message
Adrian Moser
Member
I opened ticket
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388494
Thanks for your support.
Previous Topic:Script in AbstractBrowser
Next Topic:ImageColumn
Current Time: Wed May 22 04:33:54 EDT 2013
Powered by FUDForum. Page generated in 0.02083 seconds
