| Re: Loading a plugin programmatically [message #903964 is a reply to message #903944] |
Mon, 27 August 2012 08:59   |
Chun Tat Chu Messages: 10 Registered: August 2012 |
Junior Member |
Hi Thorsten,
Here's my manifest
<!-- dc_buddypolicy_plugin1 -->
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Buddy Policy Plugin 1
Bundle-SymbolicName: dc_buddypolicy_plugin1; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: dc_buddypolicy_plugin1.Activator
Bundle-Vendor: David Chu
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ActivationPolicy: lazy
Export-Package: dc_buddypolicy_plugin1
Eclipse-RegisterBuddy: dc_buddypolicy_plugin3
<!-- dc_buddypolicy_plugin3 -->
Bundle-Name: Buddy Policy Plugin3
Bundle-SymbolicName: dc_buddypolicy_plugin3; singleton:=true
Bundle-Activator: dc_buddypolicy_plugin3.Activator
Export-Package: dc_buddypolicy_plugin3
Eclipse-BuddyPolicy: registered
I added the following code as you suggested in my dc_buddypolicy_plugin3::Activator::start() method but I am still getting a ClassNotFoundException...
Classname is dc_buddypolicy_plugin1.Logger
java.lang.NoClassDefFoundError: dc_buddypolicy_plugin1/Logger
at dc_buddypolicy_plugin3.Activator.start(Activator.java:70)
b.start();
Class<dc_buddypolicy_plugin1.Logger> logclass = b.loadClass("dc_buddypolicy_plugin1.Logger");
System.out.println("Classname is " + logclass.getName());
dc_buddypolicy_plugin1.Logger.logMsg(PLUGIN_ID + ":Activator", "start", "invoked")
I am going to look into more. Any recommendation would be appreciated. Thanks!
[Updated on: Mon, 27 August 2012 09:00] Report message to a moderator
| Re: Loading a plugin programmatically [message #903981 is a reply to message #903973] |
Mon, 27 August 2012 09:44   |
Junior Member |
I added "Bundle-ClassPath: .,/home/beyonddc/workspace/deployed_plugin/plugins/dc_buddypolicy_plugin1_1.0.0.jar" but I am still getting the NoClassDefFoundError exception.
The thing is before adding "Bundle-ClassPath" into dc_buddypolicy_plugin3, I was already able to load the Logger class by following your recommendation. I also verify that the class did loaded by invoking the getName() method. See code below...
"System.out.println("Classname is " + logclass.getName());"
I thought that piece of code will load the class into the ClassLoader. If the class did get loaded then why I couldn't use it and still getting a NoClassDefFoundError exception?
dc_buddypolicy_plugin1.Logger.logMsg(PLUGIN_ID + ":Activator", "start", "invoked");
[Updated on: Mon, 27 August 2012 09:45] Report message to a moderator
| Re: Loading a plugin programmatically [message #903984 is a reply to message #903981] |
Mon, 27 August 2012 09:57   |
Junior Member |
I changed the code to use reflection instead and then now I can invoke on the logger successfully. Why's that?
Class[] argTypes = new Class[] { String.class, String.class, String.class };
java.lang.reflect.Method logMsg = logclass.getDeclaredMethod("logMsg", argTypes);
String[] msgArgs = new String[] { "test1", "test2", "test3" };
logMsg.invoke(null, msgArgs);
Just an additional note, I do need to include the following in my dc_buddypolicy_plugin3 manifest if I need to get it to run with reflection after I exported my Eclipse RCP application.
[Updated on: Mon, 27 August 2012 10:17] Report message to a moderator
| Re: Loading a plugin programmatically [message #904233 is a reply to message #904117] |
Mon, 27 August 2012 23:43   |
Junior Member |
Thorsten Schlathölter wrote on Mon, 27 August 2012 15:58Sorry but there is a little missunderstanding. You should certainly not add /home/beyonddc/workspace/deployed_plugin/plugins/dc_buddypolicy_plugin1_1.0.0.jarto the classpath of plugin3. First of all it is an absolute path which has nothing to do in a manifest. What if you decide to give the plugin to someone else? And then if you add it to plugin3 what is the need of plugin1 anyway?
That makes sense. I was just trying different combination b/c I couldn't get it working.
You need to add the Bundle-ClassPath to the manifest if the classes are located in a jar. So for example if your logger is packed in a jar logger.jar and you place the jar into a lib folder located in your plugin, then you should add logger.jar to the classpath. In that case the classpath would be:
Bundle-ClassPath: ., lib/logger.jar
Where lib is a folder located in your plugin1.
If on the other hand your class is located in a folder dc_buddypolicy_plugin1/Logger.class and the folder itself is located in the root of dc_buddypolicy_plugin1_1.0.0.jar, then
Bundle-ClassPath: .
Is sufficient. I am not sure whether Bundle-ClassPath can be neglected in that case. At least it does not harm.
You definetly have to remove /home/beyonddc/workspace/deployed_plugin/plugins/dc_buddypolicy_plugin1_1.0.0.jar from the classpath of plugin3!!!
May I ask why you want to use the buddy policy to resolve the class from plugin1? As far as I know the buddy policy was introduced to overcome class loading issues when bundles cannot make use of the normal OSGI delegation model. Since you have a simple OSGI bundle with one class, why don't you just import the package or the bundle into plugin3? And what is the use of loading the plugin programmatically? Why don't you just add it to your configuration? Is this just a proof of concept?
Yup! It is just a proof of concept. I have an assignment that I need to generate some code from a template and then package it into an Eclipse plugin. Because the name of the package is unknown until the Eclipse plugin is generated so I want to provide a button in my RCP that will take a file location as an import and then load the plugin via the installBundle() method. After the bundle gets loaded then I would like to use it.
I thought this should be achievable because Eclipse IDE allows you to download and install a plugin without restarting the Eclipse IDE itself.
Regarding your reflection question: Why would you load the class other than to use it for reflection? If you were already able to load the class before modifying the Bundle-ClassPath then go back to that point and use the class with reflection.
Thorsten
I don't really want to use reflection. I was hoping that after installBundle() is executed then I can just use my Logger class directly and log message.
The following code is really what I want to achieve but I couldn't get it working.
public void start(BundleContext context) throws Exception {
super.start(context);
plugin = this;
System.out.println(PLUGIN_ID + ":Activator::start invoked");
try {
System.out.println(PLUGIN_ID + ":Activator::start installing bundle");
Bundle b = context.installBundle("reference:file:///home/beyonddc/workspace/exported_plugins/plugins/dc_buddypolicy_plugin1_1.0.0.jar");
System.out.println(PLUGIN_ID + ":Activator::start installed bundle");
b.start();
} catch (Throwable th) {
th.printStackTrace();
In short, I just want to load a plugin via the installBundle() method and then use the Logger class from dc_buddypolicy_plugin1 to log a message. It's just that no matter how I try this I kept getting error.
Thorsten, thanks for your help!
| Re: Loading a plugin programmatically [message #905143 is a reply to message #904233] |
Wed, 29 August 2012 15:40   |
Paul Webster Messages: 6813 Registered: July 2009 Location: Ottawa |
recap: You want to install bundle1 at runtime from bundle3 and then use it from bundle3.
bundle3 can't see your bundle1 classes by default. You'd either have to require the bundle bundle1 or import the packages from bundle1 into bundle3. But then bundle1 would have to be there at compile time for sure, and (even if optional) you would not be able to load a class that references anything from bundle3 (until after it had been installed and PackageAdmin or Wiring had been updated).
The OSGi pattern to do this would be to provide a service interface (something that will allow you to start using the bundle1 functionality). Then you have bundle1 provide the service (preferably through Declarative Services) and bundle3 would consume the service (use a ServiceTracker, for example).
Then when bundle1 is installed the service it provides (a logger?) would become available to bundle3.
PW
Paul Webster
FUDForum. Page generated in 0.01780 seconds
