Home » Modeling » AMW » [AMW] any available example with the new November, 25th 2010 version?
[AMW] any available example with the new November, 25th 2010 version? [message #904535] Tue, 28 August 2012 12:12 Go to next message
Eclipse User
AS written in the subject of the message, I am looking for a working
simple project in which the new AMw version (from November, 25th 2010)
has been used. Can someone make it available to the community?
Ivano
Re: [AMW] any available example with the new November, 25th 2010 version? [message #905005 is a reply to message #904535] Wed, 29 August 2012 10:44 Go to previous messageGo to next message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del Fabro
Most of the use cases have been used with this version.
For a simple example, check the one that is part of the plug-in user guide (simple creation of weaving links).
Marcos.
Re: [AMW] any available example with the new November, 25th 2010 version? [message #905395 is a reply to message #905005] Thu, 30 August 2012 06:01 Go to previous messageGo to next message
Eclipse User
Hi Marcos, thanks a lot for the quick reply, I manage to solve my issue,
there was a mistake in a couple of annotations in the weaving metamodel.
Anyway, I set up a clean Eclipse distribution based on Helios SR2
containing all the components of the AMMA platform, it is available
here: http://www.di.univaq.it/malavolta/files/AMMAPlatform.zip
I think it can be useful both for beginners which want to start using
the AMMA platform, and for experienced developers who need a fresh
Eclipse distribution with all the AMMA components already installed and
tested.
These are the components contained into this distribution:
AMMA (AMW, ATL, AM3), xText, Acceleo, GMF, Subclipse SVN, EMF, OCL
This distribution contains also a default workspace containing a project
with a simple weaving model.
Ivano
Il 29/08/2012 16:44, Marcos Didonet Del Fabro ha scritto:
> Hi
> Marcos.
Re: [AMW] any available example with the new November, 25th 2010 version? [message #905521 is a reply to message #905395] Thu, 30 August 2012 10:49 Go to previous message
Nice. I will keep that link.
I have prepared also a similar bundle that is available at www.inf.ufpr.br/didonet/amw/download/EclipseAMW.zip.
However, it contains essentially the necessary plug-ins to run AMW, i.e., it does not include modeling plug-ins such as xText, Acceleo or OCL.
Marcos.
Previous Topic:Problems with 'generateModelRef()' from output model.
Next Topic:AMW installation
Current Time: Tue May 21 13:25:35 EDT 2013
Powered by FUDForum. Page generated in 0.01703 seconds
