| Stop the code on error [message #901486] |
Mon, 13 August 2012 01:20  |
Anthony Liew Messages: 1 Registered: August 2012 |
Junior Member |
Hi guys,
I just want to know one thing.
How do I make it so that when an error occurs when debugging with Koneki, how do I pause execution and perform a custom function?
Is there something I need to change in debugger.lua or debuginstospection.lua?
Please reply at your earliest convenience, this issue has been plaguing my development time, and I'm really desperate.
Thanks in advance
[Updated on: Mon, 13 August 2012 01:22] Report message to a moderator
| Re: Stop the code on error [message #902495 is a reply to message #901486] |
Fri, 17 August 2012 18:46   |
Hi Anthony,
Not sure I get your question :/ What do you mean by "when an error occurs when debugging with Koneki"?
Thanks for taking time to clarifying, hopefully I can help you then!
Benjamin
| Re: Stop the code on error [message #904914 is a reply to message #904857] |
Wed, 29 August 2012 07:21  |
Benedikt Roland Messages: 6 Registered: August 2012 |
Junior Member |
I just thought he would work around with the debugging-perspective.
I also develop Python and Java stuff. You can run a little bit of java when in python an error occurs (so it pauses and did not stop/exit). it runs python-code, but on an error you can Java-code(I am talking of plugin-code). I thought he meant that, but maybe ... he meant something other...
FUDForum. Page generated in 0.01805 seconds
