| Re: Subversion's "Compare with" function [message #904829 is a reply to message #826767] |
Wed, 29 August 2012 04:24  |
Mauro Molinari Messages: 277 Registered: July 2009 |
Il 22/03/2012 14:35, Natalia Yakovleva ha scritto:
> Hi all, I have a problem, don't understand how to resolve...
> I am using the Subversion from Eclipse enviroment. I'd like to compare two branches. As I have understood from documentation, it should be possible to compare two directories (not only two files). But when I select some branch and select "Compare with..." in menu (as shown in picture in attachment), then items "URL", "Branch", "Tag" "Each other" are disabled.
Now I can see your screenshot correctly... I don't know why :-?
Anyway, maybe your project layout on the SVN repository does not respect
the canonical trunk/branches/tags structure expected by Subversive?
If you use a non-standard layout, you may tell it to Subversive by doing
this: open the SVN Repositories view, right click on your repository,
click on Location Properties..., then go to the Advanced tab, check
"Enable Structure Detection" and change the resource names if needed.
Mauro.
FUDForum. Page generated in 0.01631 seconds
