Home » Eclipse Projects » Plugin Development Environment (PDE) » File Path to jar inside another jar(Path seems to be non-valid)
File Path to jar inside another jar [message #904563] Tue, 28 August 2012 13:30 Go to next message
Cedric Reichenbach is currently offline Cedric Reichenbach
Hi y'all
For an Eclipse plugin, I need to refer to a jar file inside the plugin directory (to provide code to users). This works perfectly when running the plugin while developing (inside a runtime-eclipse-application).
But when I build an update site, my plugin is built into a jar file. File paths for images are still working, but when the jar should be imported, eclipse shows the following error:
Description Resource Path Location Type The container 'DoodleDebug' references non existing library 'file:\C:\Users\Me\.eclipse\org.eclipse.platform_3.7.0_740800064\plugins\ch.unibe.scg.doodledebug_1.0.0.201208281642.jar!\DoodleDebug-Client.jar'
The outer jar path is correct and when inspecting it with WinRAR, I can see the desired jar file inside it!
Why isn't this working as expected?
Cheers
Cedric
Re: File Path to jar inside another jar [message #904938 is a reply to message #904563] Wed, 29 August 2012 08:18 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph Carroll
What does your manifest look like?
You should have something that looks like:
Bundle-ClassPath: lib/com.foo.jar,
Including the '.' on a separate line is important.
JD
Re: File Path to jar inside another jar [message #905001 is a reply to message #904938] Wed, 29 August 2012 10:37 Go to previous messageGo to next message
Thanks for your reply, but I could solve it now:
I had to set
Eclipse-BundleShape: dir
in my MANIFEST.MF (directly in source code) and set a tick at
Unpack the plug-in archive after the installation
under the tab "Plug-ins", so my plugin is installed in an exploded form instead of in an archive.
Directly refer to a jar inside another one seems to be impossible.
Cheers
Cedric
Re: File Path to jar inside another jar [message #905474 is a reply to message #905001] Thu, 30 August 2012 08:51 Go to previous messageGo to next message
Glad its working and good to know Wink
JD
Re: File Path to jar inside another jar [message #906047 is a reply to message #905474] Fri, 31 August 2012 10:13 Go to previous messageGo to next message
Curtis Windatt is currently offline Curtis Windatt
Nested Jars are not supported. We can request files from inside a plug-in, but there is no ability to extract context from a jar inside a jarred plug-in. The solution we have traditionally used is the one Cedric suggests last, changing the plugin shape to be a directory.
Depending on your use case, it is possible to extract data from the jar file, but you must do so manually (explode it into a temporary directory then extract the necessary files yourself).
Re: File Path to jar inside another jar [message #906103 is a reply to message #906047] Fri, 31 August 2012 12:13 Go to previous message
But I could use Images from within the plugin jar, or does eclipse create some kind of a virtual copy when using
ImageDescriptor.createImage()
Previous Topic:Creating extensions in plugin.xml programmatically?
Next Topic:Reading resources from a Eclipse plugin ?
Current Time: Sun May 19 01:50:51 EDT 2013
Powered by FUDForum. Page generated in 0.01705 seconds
