| How to launch Equinox 3.8 to console? [message #904546] |
Tue, 28 August 2012 12:49  |
Hi everbody,
I'm almost afraid of asking you but how to launch Equinox 3.8 with console?
In Equinox 3.7 I was used to
$ java -jar ~/path/to/org.eclipse.osgi_3.7.2.v20120110-1415.jar -console
This morning I've just downloaded Equinox 3.8 SDK and issuing
$ java -jar
~/path/to/equinox-SDK-3.8/plugin/org.eclipse.osgi_3.8.0.v20120529-1548.jar
-console
does nothing. Equinox doesn't quit but doesn't present a console.
However jps or VisualVM reveals that it's running (probably) normally.
** Was -console option removed? **
Appending -consoleLog forces Equinox JAR to show me at least this:
!ENTRY org.eclipse.osgi 4 0 2012-08-28 18:48:20.101
!MESSAGE Could not find bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not find bundle:
org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:211)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:297)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
org.eclipse.core.runtime.adaptor.EclipseStarter.main(EclipseStarter.java:151)
Last but not least: Where are changes 3.7 -> 3.8 documented, please?
Libor
| Re: How to launch Equinox 3.8 to console? [message #904930 is a reply to message #904765] |
Wed, 29 August 2012 08:00   |
Hello Lazar,
thank you so much. Have to say sorry to missed checkout a Juno's online
help at first.
What is Gogo good for? Why old console is removed (okay, disabled by
default)? Issuing "help" in Gogo flooded my screen with tons of
something cryptic text that is not helpful anyway to me.
I tried to read all what Google offered to me when searching for OSGi
RFC132 and Felix Gogo but no document/blogpost shown me what is
motivation or user advantage of this...
This is not intention to start a flame war, just a Equinox 3.8 newcomer
question.
Thanks a lot in advance!
Libor
On 08/29/2012 07:54 AM, Lazar Kirchev wrote:
> Hello Libor,
> Changes in Equinox console 3.7 -> 3.8 are described here:
> http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fporting%2F4.2%2Fincompatibilities.html&cp=2_3_0_2&anchor=osgiconsole
> but essentially the new console in Equinox 3.8 is described here (the
> above documents links to this one):
> http://help.eclipse.org/juno/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/console_shell.htm
> The most important change is that the console is no longer part of the
> framework bundle, it is detached in its own bundle,
> org.eclipse.equinox.console. It also depends on Apache Gogo shell. So
> the following 4 shell bundles should be started with the Equinox
> framework bundle in order to have a running console:
> org.apache.felix.gogo.runtime
> org.apache.felix.gogo.command,
> org.apache.felix.gogo.shell
> The second of the above documents describes how to start the console.
> You could list the four bundles as a value of the property osgi.bundles,
> either in config.ini file, or as a system argument on command line.
> HTH
> Lazar
| Re: How to launch Equinox 3.8 to console? [message #904935 is a reply to message #904930] |
Wed, 29 August 2012 08:05  |
I appreciate tab-completion, SSH/telnet, JAAS, ... but what are other
benefits/motivation of RFC132/Gogo....
And, OMG, how to paginate output of help? Good old "more" is gone
("gogo: CommandNotFoundException: Command not found: more")...
Libor
On 08/29/2012 02:00 PM, Libor Jelinek wrote:
> Hello Lazar,
> help at first.
> question.
> Libor
>> Hello Libor,
>> HTH
>> Lazar
FUDForum. Page generated in 0.01853 seconds
