Home » Eclipse Projects » Jubula » How to start AUT which is JNLP
How to start AUT which is JNLP [message #902620] Thu, 16 August 2012 23:03 Go to next message
Lizzy Liu is currently offline Lizzy Liu
I want to use Jubula do the test for a Java Swing C/S project, and this product is started by jnlp file.
I tried to wrap this jnlp file in a bat file, the format is like this:
@echo off
C:\Windows\System32\javaws.exe h-t-t-p://192.xx.xx.xx/java-client/app/launch.jnlp
Or with this: (Note: This is the same with the settings in the properties of the shortcut of this project after have download once:)
C:\Windows\System32\javaws.exe -localfile "C:\Program Files\jubula_6.0.00072\examples\AUTs\SimpleAdder\swing\56ae210e-5deadec4"
But all these can't work, I have start the aut agent and have connected to it, and add the test case to the test suite, and opened the object mapping node.
Would you please tell me how I can start the AUT which is jnlp with the Jubula? Thanks a lot.
Re: How to start AUT which is JNLP [message #903988 is a reply to message #902620] Mon, 27 August 2012 10:01 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
Crosslink: Answer posted in second thread:
http://www.eclipse.org/forums/index.php/t/369608/
Previous Topic:Problems with the lock manager
Next Topic:Each Test Suite requires an AUT setting for Execution. New
Current Time: Thu May 23 00:55:00 EDT 2013
Powered by FUDForum. Page generated in 0.01562 seconds
