Home » Eclipse Projects » Memory Analyzer » Thread Details/Overview won't open: Object 0x2aab50739d48 not found.(Cannot open the Thread Details or Thread Overview and Stacks options)
Thread Details/Overview won't open: Object 0x2aab50739d48 not found. [message #902821] Mon, 20 August 2012 11:36 Go to next message
Joel Patton is currently offline Joel Patton
I cannot open the Thread Details or the Thread Overview and Stacks options. Every time I try I get an error message "Object [address] not found". This happens across multiple .hprofs. I'm not sure if I'm using it correctly: when I select Thread Overview and Stack, I get a dialog asking for "objects". I leave it blank and hit Finish and then I get the error. Any thoughts? Thanks!
-Joel
org.eclipse.mat.SnapshotException: Object 0x2aab50739d48 not found.
at org.eclipse.mat.parser.internal.SnapshotImpl.mapAddressToId(SnapshotImpl.java:1457)
at org.eclipse.mat.parser.internal.ThreadStackHelper.readLocalId(ThreadStackHelper.java:134)
at org.eclipse.mat.parser.internal.ThreadStackHelper.loadThreadsData(ThreadStackHelper.java:71)
at org.eclipse.mat.parser.internal.SnapshotImpl.getThreadStack(SnapshotImpl.java:2006)
at org.eclipse.mat.inspections.threads.ThreadOverviewQuery.buildThreadOverviewNode(ThreadOverviewQuery.java:142)
at org.eclipse.mat.inspections.threads.ThreadOverviewQuery.execute(ThreadOverviewQuery.java:92)
at org.eclipse.mat.query.registry.ArgumentSet.execute(ArgumentSet.java:129)
at org.eclipse.mat.ui.QueryExecution$ExecutionJob.run(QueryExecution.java:174)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: Thread Details/Overview won't open: Object 0x2aab50739d48 not found. [message #903907 is a reply to message #902821] Mon, 27 August 2012 04:23 Go to previous messageGo to next message
Andrew Johnson is currently offline Andrew Johnson
Member
The problem is that one of the thread local variables found in the stacks in the dump is not found in the heap.
You could list the thread objects using the 'list_objects' query
java.lang.Thread
(more options)
include subclasses
and run the thread overview and stacks query on a subset of the result and see if you can get information on most of the threads. (At least one will fail with the same problem you saw).
You could edit the <heap dump name>.threads index file and remove the line containing
objecId=0x2aab50739d48, line=<nn>
This would stop the that thread local from being inspected.
If this is common problem then we could update the query to bypass the failure.
What version of JVM generated the dump?
Re: Thread Details/Overview won't open: Object 0x2aab50739d48 not found. [message #903972 is a reply to message #903907] Mon, 27 August 2012 09:17 Go to previous message
The JVM version is: 1.6.0_20
This has been a common problem for me. The past 6 or so dumps I've analyzed have all encountered this error, so if you can create a workaround for it then that would be great!
I'll try your suggestions on my next hprof. Thank you!
Joel
Previous Topic:Can I see the contents of the generations?
Next Topic:Is heap dump file platform dependant?
Current Time: Sat May 25 23:17:35 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
