| Declaring NULL capable variables [message #903930] |
Mon, 27 August 2012 06:59  |
Richard Moulton Messages: 79 Registered: August 2011 Location: Devon, UK |
Member |
When defining a simple value variable I know how to define the field as NULL capable, such as the following, and understand that by default the field will contain a NULL value.
myInt int?;
myString string?;
But how do I declare an array as being NULL capable?
I tried all of the following and they all appear to be valid but I don't understand the difference.
myIntArray1 int[]?;
myIntArray2 int?[];
myIntArray3 int?[]?;
As a side note the section within code snippets, on the EDT:Declaring data page, I think there's a typo; the second example in the Values of type List isn't correct. Once I know the answer (to the above question) I can update it.
Richard
| Re: Declaring NULL capable variables [message #903954 is a reply to message #903930] |
Mon, 27 August 2012 08:41  |
Justin Spadea Messages: 66 Registered: July 2009 |
Member |
Hi Richard,
Here's an explanation of each array type:
myIntArray0 int[];
The array field cannot be null, and elements in the array cannot be null.
myIntArray1 int[]?;
The array field can be null, but elements in the array cannot be null.
myIntArray2 int?[];
The array field cannot be null, but elements in the array can be null.
The array field can be null, and elements in the array can be null.
You are correct about the snippet being wrong, it should be "nullVals Int?[];"
Hope this clears things up.
-Justin
FUDForum. Page generated in 0.01722 seconds
