Home » Newcomers » Newcomers » debugging struts using eclipse
debugging struts using eclipse [message #903112] Wed, 22 August 2012 01:20 Go to next message
howard hardaway is currently offline howard hardaway
I am tring to debug struts using eclipse and I am getting the following error:
Source not found. and it is on the following line:
LoginAction.execute(ActionMapping,ActionForm,HttpServletRequest,HttpServletResponse)
I have added the source jakarta-struts-1.1-src.zip but it does not work. Are there any examples that show how to do this.
Howard
Re: debugging struts using eclipse [message #903676 is a reply to message #903112] Fri, 24 August 2012 16:49 Go to previous messageGo to next message
Duncan Krebs is currently offline Duncan Krebs
Member
I did not seee that class in the struts jar, not totally sure but you might be testing a sample app that has a custom class called LoginAction that extends Action which is why you are not able to view the source as I don't think its part of the lib.
Re: debugging struts using eclipse [message #903754 is a reply to message #903676] Sat, 25 August 2012 10:20 Go to previous message
Javin Paul is currently offline Javin Paul
Member
On related note While debugging framework code like Spring or Struts its best to attach source with JAR, this will makes debugging easy and your breakpoint will take you on correct place in source.
Previous Topic:Trouble in CSS
Next Topic:Eclipse WAR builds contains .java files
Current Time: Sat May 25 07:52:33 EDT 2013
Powered by FUDForum. Page generated in 0.01551 seconds
