Home » Modeling » Graphiti » Custom properties sheet
Custom properties sheet [message #902755] Mon, 20 August 2012 05:34 Go to next message
Rui Domingues is currently offline Rui Domingues
Is there any problem in defining composites with swt widgets and bind them with business objects with jfaces, instead of using tabbed properties or traditional properties.
There is any problem with resources or something else I have to workaround, or is it straight forward?
Thanks in advance
Rui
Re: Custom properties sheet [message #902788 is a reply to message #902755] Mon, 20 August 2012 09:10 Go to previous messageGo to next message
I'm trying to implement a custom property view, and I noticed that emf object doesnt support property firing. Why is this ?
Re: Custom properties sheet [message #903703 is a reply to message #902755] Mon, 20 August 2012 07:54 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
What would be the advantage over using TabbedPropertySheets? Isn't this
somehow "re-inventing the wheel"?
Michael
Re: Custom properties sheet [message #903704 is a reply to message #902788] Wed, 22 August 2012 03:19 Go to previous message
Not sure what you mean with "property firing"? You can install adapters to
Eobjects that get notified on changes, is that what you are looking for?
But, since this is EMF related I would suggest to rather post this in the
EMF forum.
Michael
Previous Topic:Resize shape (only horizontal)
Next Topic:mathematical expressions editor
Current Time: Sat May 25 02:54:55 EDT 2013
Powered by FUDForum. Page generated in 0.02009 seconds
