Home » Modeling » Graphiti » org.eclipse.swt.SWTException: Failed to execute runnable
org.eclipse.swt.SWTException: Failed to execute runnable [message #902221] Thu, 16 August 2012 08:24 Go to next message
Surya Kathayat is currently offline Surya Kathayat
Member
I am getting the following exception while I select/mode elements within a graphiti based editor.
I exactly don't know when this will happen, it happens in an unexpected manner and frizes entire application.
Exceptions seems to happen (looking at the exception trace) while redrawing/repainting something, not sure what!!! any ideas or experiences??
Best Regards
Surya
!ENTRY org.eclipse.ui 4 0 2012-08-16 14:17:26.606
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Graphic is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at com.sap.idm.ic.rcp.Application.start(Application.java:22)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.graphics.GC.getBackground(GC.java:3269)
at org.eclipse.draw2d.SWTGraphics.init(SWTGraphics.java:791)
at org.eclipse.draw2d.SWTGraphics.<init>(SWTGraphics.java:263)
at org.eclipse.draw2d.DeferredUpdateManager.paint(DeferredUpdateManager.java:152)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem.java:203)
at org.eclipse.draw2d.LightweightSystem$2.handleEvent(LightweightSystem.java:110)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1463)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4585)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.RedrawWindow(Native Method)
at org.eclipse.swt.widgets.Control.update(Control.java:4380)
at org.eclipse.swt.widgets.Control.update(Control.java:4370)
at org.eclipse.draw2d.NativeGraphicsSource.getGraphics(NativeGraphicsSource.java:48)
at org.eclipse.draw2d.DeferredUpdateManager.getGraphics(DeferredUpdateManager.java:147)
at org.eclipse.draw2d.DeferredUpdateManager.repairDamage(DeferredUpdateManager.java:310)
at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(DeferredUpdateManager.java:192)
at org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(DeferredUpdateManager.java:44)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 23 more
Re: org.eclipse.swt.SWTException: Failed to execute runnable [message #903701 is a reply to message #902221] Mon, 20 August 2012 07:41 Go to previous message
Michael Wenz is currently offline Michael Wenz
Hm, that's hard to track back. It seems some kind of asynchronous refresh is
running for an already closed diagram - at least usually that is the cause
for such exceptions, although that appears strange on move or select.
Unfortunatly the caused by stacktract doesn't go back enough the see the
cause. Are there any file modification operations involved? I'm asking
because they might trigger diagram refreshes from the background.
Michael
Previous Topic:Drag and Drop
Next Topic:Populating Diagram with all domain objects
Current Time: Sat May 18 12:32:32 EDT 2013
Powered by FUDForum. Page generated in 0.01923 seconds
