Home » Eclipse Projects » EclipseLink » View as JoinTable causes delete problem
View as JoinTable causes delete problem [message #903670] Fri, 24 August 2012 16:06 Go to next message
Jeremy Purdy is currently offline Jeremy Purdy
I have a one-to-many mapping that is using an Oracle view as the JoinTable because the relationship between the two objects is complex inside of the database. The mapping is here:
<one-to-many name="bars" fetch="EAGER">
<join-table name="FOO_BARS_VIEW">
<join-column name="FOOID" referenced-column-name="ID" insertable="false" updatable="false" nullable="false"/>
<inverse-join-column name="BARID" referenced-column-name="ID" insertable="false" updatable="false" nullable="false"/>
</join-table>
</one-to-many>
This works fine for queries, etc.
However, when I attempt to delete a FOO object, eclipselink is cascading the delete into the view:
DELETE FROM FOO_BARS_VIEW WHERE (FOOID = ?)
bind => [301]
This statement fails, since you can't delete from a view.
Is there a way to tell JPA not to cascade the delete into the JoinTable?
Re: View as JoinTable causes delete problem [message #903998 is a reply to message #903670] Mon, 27 August 2012 10:17 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
I assumed that marking all fields as insertable=false, updatable=false would make the mapping read only, but it looks like you will need to use a customizer to get the mapping and mark it directly using the setIsReadOnly(true) method.
Descriptor customizers are described here:
http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/Customizers
with the following code being required:
descriptor.getMappingForAttributeName("bars")).setIsReadOnly(true);
Best Regards,
Chris
[Updated on: Mon, 27 August 2012 10:29]
Report message to a moderator
Previous Topic:Problem in running QueryHints.READ_ONLY on GF 3.0
Next Topic:merging returns old value for referenced entity
Current Time: Tue May 21 23:53:40 EDT 2013
Powered by FUDForum. Page generated in 0.01639 seconds
