Home » Eclipse Projects » Jubula » Jubula doesn't recognize drop down menu(drop down menu of AUT not recognized during object mapping)
Jubula doesn't recognize drop down menu [message #903637] Fri, 24 August 2012 11:41 Go to next message
Erik Gilbert is currently offline Erik Gilbert
Member
Labels and tabbed panes are being recognized in the AUT during object mapping mode and are appearing in the Unassigned technical names box with ctrl-shift-Q but the drop down menu is not being recognized. What can I do so the drop down menu is recognized?
Re: Jubula doesn't recognize drop down menu [message #903995 is a reply to message #903637] Mon, 27 August 2012 10:10 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
Working with context menus doesn't involve mapping each entry, but rather the component on which you want to open the menu on (e.g. the tree, table, button etc.)
There's a cheat sheet I'd recommend doing (start it via Help - Cheat Sheets) and this thread may also be useful.
HTH,
Alex
Re: Jubula doesn't recognize drop down menu [message #905921 is a reply to message #903995] Fri, 31 August 2012 06:08 Go to previous messageGo to next message
Member
Yes, I see the drop down menu is not mapped with object mapping, but that there is a specific unbound module I can use for drop down menus ub_mbr_selectEntry_byTextpath
But thanks for the links and suggestions.
Re: Jubula doesn't recognize drop down menu [message #907188 is a reply to message #905921] Mon, 03 September 2012 09:35 Go to previous message
If you're talking about the main menu at the top of the application, then the action you mentioned is correct. No mapping is needed, because main menus are found automatically.
If you're talking about context menus (pop up menus) then the steps in the cheat sheet are the ones you need.
If you're talking about toolbar items with drop down menus (like the "Start AUT" button in Jubula), then there are also specific actions for this in the SWT unbound modules.
HTH,
Alex
Previous Topic:What happens on java.lang.OutOfMemoryError: PermGen space
Next Topic:"Default Event Handler" is triggered instead of my customized handler
Current Time: Fri May 24 10:18:10 EDT 2013
Powered by FUDForum. Page generated in 0.01975 seconds
