| Please help, e4 and org.eclipse.help [message #903617] |
Fri, 24 August 2012 10:49  |
nikolaz nikolaz Messages: 1 Registered: August 2012 |
Junior Member |
Hi. I have pure e4 RCP application. Now I got additional requirement to add a Help.
When I'm trying to add org.eclipse.help, org.eclipse.help.base and org.eclipse.help.ui I'm having the following error:
!ENTRY org.eclipse.equinox.app 0 0 2012-08-24 17:32:55.302
!MESSAGE Product com.vendor.studio.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2012-08-24 17:32:55.352
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-08-24 17:32:55.353
!MESSAGE Bundle initial@reference:file:workspace/com.vendor.studio/ was not resolved.
!SUBENTRY 2 com.vendor.studio 2 0 2012-08-24 17:32:55.353
!MESSAGE Missing required bundle org.eclipse.help.base_3.6.100.
!MESSAGE Missing required bundle org.eclipse.help.ui_3.5.200.
I've also added dependencies to equinox.ds, equinox.event, equinox.util as mentioned in tutorial by Jonas Helming and Max Koegel. But still the same. Please prompt me, what is missing? Idea is to use pure e4 + some parts from legacy 3.x. I've read multiple tutorials on compatibility layer, but still can't run my project with help plugin on e4 rcp. Please prompt.
[Updated on: Fri, 24 August 2012 12:00] Report message to a moderator
| Re: Please help, e4 and org.eclipse.help [message #903940 is a reply to message #903725] |
Mon, 27 August 2012 07:30  |
Brian de Alwis Messages: 242 Registered: July 2009 |
Unfortunately you can't use the org.eclipse.ui.help from a pure E4 app at the moment: the E3.x compatibility layer requires fully buying into the Eclipse 3.x workbench and platform. It's one of the goals of 4.3 to relax this constraint, and you're welcome to help adapt org.eclipse.help.ui to make it so,
FUDForum. Page generated in 0.01673 seconds
