Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] JSONTexoResource, DynamicModelObject support(Texo support for JSONTexoResource, DynamicModelObject)
[Texo] JSONTexoResource, DynamicModelObject support [message #896604] Thu, 19 July 2012 02:42 Go to next message
Neeraj Bhusare is currently offline Neeraj Bhusare
Member
Any update on the implementation of the JSONTexoResource? Also, any pointers/samples on the DynamicModelObject support. The wiki states that the first implementation is available.
Best regards, Neeraj
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #896790 is a reply to message #896604] Thu, 19 July 2012 15:09 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Neeraj,
No update at the moment since the blog post..., the dynamic model object is being used inside of Texo but I don't have
to many specific test cases for it. What do you want to do?
gr. Martin
On 07/19/2012 08:42 AM, Neeraj Bhusare wrote:
> Any update on the implementation of the http://wiki.eclipse.org/Texo/EMFResource? Also, any pointers/samples on the
> DynamicModelObject support. The http://wiki.eclipse.org/Texo/Texo_and_EMF states that the first implementation is
> available.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #897336 is a reply to message #896790] Mon, 23 July 2012 11:57 Go to previous messageGo to next message
Member
Hi Martin,
Sorry for the delayed reply. There are two things that I need to do - 1) Dynamically creating meta-model on the server side. If I am not wrong, I could use the Texo dynamic model object support. 2) Something similar to the 3-Tier architecture - An RCP client, Webservices and a Database.
So far I have tried the XML/JSON REST Web Service samples and I am looking forward to make use of it. However, I would like to know if you have anything planned for the "TexoJSONResource" implementation. Also, is there an alternative available for now.
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #897432 is a reply to message #897336] Tue, 24 July 2012 02:48 Go to previous messageGo to next message
Hi Neeraj,
Both topics have my clear interest to have/add them (which means that it could be done within a month or so), maybe the
first works fine but this part has not been tested thoroughly. For the json emf resource the skeleton code is there but
I need to finish the implementation.
Can you ping/come back in a few weeks from now? Actually, it is no problem to just ask again every week... I am most of
the time quite busy but sometimes/often I can/will do this in between my other work.
gr. Martin
On 07/23/2012 05:57 PM, Neeraj Bhusare wrote:
> Hi Martin,
> http://wiki.eclipse.org/Texo/EMFResource - An RCP client, Webservices and a Database.
> So far I have tried the http://wiki.eclipse.org/Texo/JSON_REST_Web_Services samples and I am looking forward to make use
The Netherlands
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #897438 is a reply to message #897432] Tue, 24 July 2012 03:17 Go to previous messageGo to next message
Member
Thanks Martin. I'll check with you in a couple of weeks.
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #903598 is a reply to message #896604] Fri, 24 August 2012 09:31 Go to previous messageGo to next message
Member
Hi Martin,
Any update on above?
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #903647 is a reply to message #903598] Fri, 24 August 2012 12:32 Go to previous messageGo to next message
Hi Neeraj,
Good that you ask :-), I am working on it right now... But ping me again next week or so if you don't hear anything.
gr. Martin
On 08/24/2012 03:31 PM, Neeraj Bhusare wrote:
> Hi Martin,
The Netherlands
Re: [Texo] JSONTexoResource, DynamicModelObject support [message #903839 is a reply to message #903647] Sun, 26 August 2012 03:55 Go to previous message
Member
Sure.
Previous Topic:[EMF Compare] opening editor programmatically results in unexpected/wrong view
Next Topic:[Acceleo] Capability Question
Current Time: Thu May 23 13:43:54 EDT 2013
Powered by FUDForum. Page generated in 0.02179 seconds
