Home » Language IDEs » AJDT » AspectJ: would it work in this case?
AspectJ: would it work in this case? [message #903552] Fri, 24 August 2012 05:25
V G is currently offline V G
We use some software, that is actually a Web Module with its own Tomcat and shell scripts for controlling it. It has also a Plugin System, which allows you to upload a .jar file with a certain structure to add new functionality to the Application.
Question:
I would like to control&actually change the responses to different calls in the main system/application (not in my jar). Could I use AspectJ to do that? Why or why not? What would be the other general possibilities, except changing the code of the Main Application.
Thank you
Previous Topic:AspectJ Projects Broken After Updating AJDT
Next Topic:Inconsistent workspace state with declare parents
Current Time: Sun May 19 07:00:36 EDT 2013
Powered by FUDForum. Page generated in 0.01754 seconds
