Home » Eclipse Projects » EGit » Missing "Multi-Pull"
Missing "Multi-Pull" [message #902552] Sat, 18 August 2012 07:26 Go to next message
ZFabrik Missing name is currently offline ZFabrik Missing name
just one small suggestion: It would be cool if one could select multiple repositories in EGit's repositories view and choose "pull all". This is not possible in version 2.0, but it would save some clicks Wink
Re: Missing "Multi-Pull" [message #902557 is a reply to message #902552] Sat, 18 August 2012 08:04 Go to previous messageGo to next message
R Shapiro is currently offline R Shapiro
You can do this already in Explorer views, for example, the Package Explorer in a Java project. Strangely, multi fetch is not. Surely if egit/jgit can perform fetch+merge on multiple repos, it should be trivially easy to perform the fetch without the merge?
Re: Missing "Multi-Pull" [message #903516 is a reply to message #902557] Fri, 24 August 2012 01:45 Go to previous message
Matthias Sohn is currently offline Matthias Sohn
With nightly build version I am able to select multiple repositories in the repositories view and click "Pull".
And yes it's a trivial change to provide fetch with multi-selection.
Previous Topic:Not Able to switch from one branch to another
Next Topic:JGit Adding Files
Current Time: Fri May 24 21:32:24 EDT 2013
Powered by FUDForum. Page generated in 0.01537 seconds
