Home » Modeling » M2T (model-to-text transformation) » [XPAND] Cast Exception when opening XPAND File
[XPAND] Cast Exception when opening XPAND File [message #899956] Fri, 03 August 2012 04:01 Go to next message
Patrick Schmitt is currently offline Patrick Schmitt
Member
Hello guys,
when I do open a xpand file with the eclipse editor,
complete document is marked as error,
i get following exception:
org.eclipse.xpand.ui.core.internal.XpandResourceImpl cannot be cast to org.eclipse.internal.xtend.xtend.XtendFile
http://s14.postimage.org/squzqqz5t/screenshot.png
Any ideas?
Kind regards,
Patrick
[Updated on: Fri, 03 August 2012 04:03]
Report message to a moderator
Re: [XPAND] Cast Exception when opening XPAND File [message #899965 is a reply to message #899956] Fri, 03 August 2012 05:05 Go to previous messageGo to next message
Member
Found the problem.
There had been a file function.ext and function.xpt in the same directory, that caused the exception.
Looks like a Bug.
Re: [XPAND] Cast Exception when opening XPAND File [message #903494 is a reply to message #899965] Thu, 23 August 2012 18:24 Go to previous message
Karsten Thoms is currently offline Karsten Thoms
Hi Patrick,
Partially. Both files would have the same Identifier.
~Karsten
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
Previous Topic:Re: Acceleo and Xtext
Next Topic:[acceleo] standalone, no emtl found
Current Time: Tue May 21 19:41:48 EDT 2013
Powered by FUDForum. Page generated in 0.04437 seconds
