| Selection is cleared in IE9 [message #903479] |
Thu, 23 August 2012 15:14  |
DANIEL Missing name Messages: 12 Registered: July 2011 Location: TORONTO |
Junior Member |
RAP 1.5
We are experiencing a problem only in IE7 and IE9 during right click in a Text widget. If the user selects a text in the Text widget and then press right click, the selection is cleared and our pop-up menu is displayed. The selection should not be cleared when you right click. The problem occurs only when we set a context menu in the Text widget. If the Text widget will have no context menu then the browser default context menu (copy, paste,...) is displayed and the selection is not cleared.
To easily reproduce this problem, use the mail demo example, and add the lines below to the end of the createPartControl method in the view class.
final AboutAction action = new AboutAction(Activator.getDefault().getWorkbench().getActiveWorkbenchWindow());
MenuManager menuManager = new MenuManager("menu"); //$NON-NLS-1$
menuManager.add(action);
menuManager.update();
Menu menu = menuManager.createContextMenu(parent);
text.setMenu(menu);
[Updated on: Thu, 23 August 2012 16:28] Report message to a moderator
FUDForum. Page generated in 0.01633 seconds
