Home » Eclipse Projects » Orbit » GWT missing requirement
GWT missing requirement [message #658379] Tue, 08 March 2011 04:16 Go to next message
fehrin2  is currently offline fehrin2
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I am trying to install the latest Orbit p2 bundle over eclipse 3.6.2
(Vista/JDK 64bit) but i get an error for
Google Web Toolkit User Library (with source)
saying
Cannot complete the install because one or more required items could not
be found.
Software being installed: Google Web Toolkit User Library (with
source) 2.1.0.v20101206-1430 (com.google.gwt.user 2.1.0.v20101206-1430)
Missing requirement: Google Web Toolkit User Library (with source)
2.1.0.v20101206-1430 (com.google.gwt.user 2.1.0.v20101206-1430) requires
'com.google.gwt.user com.google.gwt.user.browser.runtime [1.0.0,2.0.0)'
but it could not be found
I cannot find the latter anywhere in the net.
Best regards
Franz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.12 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJNdfPeAAoJEETPNNlkrKDy8x0H/3koUU3o7YoG6qgmzKkF 7ism
fcNw2iBbvP9fnD3OA0TtOpUkXTs3tvPnb7GC5vw0ObfVG09nnby1Pkawj+Hq gHv1
Wu0SPy/R5RHnIT15tBidzeS/zuOqZd1grdBJIbgrkUzkCil6WMM/aSecSgOD YS87
YcZqMjok1DGrAaHv5/0S3LtehlRiSdyFWkUtkS5FjGM8u0dMAWeSNaQR8IWD LscA
1yb8qDUVcIcGAyoazyp9EoviyBAuw5dxFSrmbTtiQN4oEfzQc4AonYCYb3+3 Ln5z
WJDNfjhvvm6l1Pk2ALVP7v5LQx3HwAi4hENu3n19okd8jSmJ/q/UJmfB41BW Rl4=
=SfdK
-----END PGP SIGNATURE-----
Re: GWT missing requirement [message #658380 is a reply to message #658379] Tue, 08 March 2011 04:18 Go to previous messageGo to next message
Hash: SHA1
I used
http://download.eclipse.org/tools/orbit/downloads/drops/S201 10304120314/repository/
as update site but the issue was present with all Orbit p2 bundles i
tried so far.
Am 08.03.2011 10:16, schrieb Franz Fehringer:
> Hello,
> saying
> be found.
> Best regards
> Franz
iQEcBAEBAgAGBQJNdfR4AAoJEETPNNlkrKDyqtoH/R/wZbUWTYHOzXNrC+jx /MwH
r+JZrB/qHFCy9vIW12XTeFwhZR9bjEo/glpjUqs13YTKr8UHZUKrrnmXcDCd L6eS
ckh9gVc5qKzjPexeZmC8tTfLsfnUJ5FlV4I7bBXkb75xZV59QuRV4bCMDxTo 4lv9
WHfuyYLGyRGb4EF54ElnUh3UCMBN5ATb3GGfHGJlayMb40rBRAFtMVaMf1Ui V8in
iW1xyWwgU14qVxP/jQBvfurS6BSvD2qrllN3IM2HBdpZxiSO4zMa56N9uOc/ +ptb
xSWq7h7iyTYAxnahTzymPyBy6eWzhmJOB6PvLT8aGDTKCJ70S/AFdm2BIaBv Vn4=
=fJ5U
Re: GWT missing requirement [message #658419 is a reply to message #658379] Tue, 08 March 2011 08:02 Go to previous messageGo to next message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
The GWT User Library must not be installed _into_ an Eclipse
installation. It's only of use in a target platform.
http://www.modumind.com/2008/04/21/why-create-a-custom-targe t-platform/
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: GWT missing requirement [message #658423 is a reply to message #658419] Tue, 08 March 2011 08:20 Go to previous messageGo to next message
Hash: SHA1
So how do i know which Orbit plugins are to be installed into an Eclipse
installation?
Am 08.03.2011 14:02, schrieb Gunnar Wagenknecht:
> -Gunnar
iQEcBAEBAgAGBQJNdi0SAAoJEETPNNlkrKDyPsEH/ilM4a14hSFzM/1vVX+w F7SN
JsL9kJnngjJkTcgorTI0VA8ft5cK4LYzU5ef6P3M8h3QXqfiKT+NONIUgb2z 75v/
3RHK9p+BswMEhQ1kdLKdqbHRIJPhAH+L6HGlLJoTz8DfT0LZF4G5s4x2JfG7 3BCs
S5SEilzD6JYi2I7CJ6RkZCNl0xehJeeN+13MVWlMrL2uk/8IBUiPOk/xjyhV FxmD
+hOVCecoMe7mxreQ3qq/jvIwWdqdkTZoFShblNObl9MYsiFlPQC82OIyG1Nj ZDiH
kaJjyQ+ElP8e3cvlOn+ordL5ZTIhq9ejGOWqrJoSG1dP1HFcBvUfr9RqZ/AZ HZk=
=3z2s
Re: GWT missing requirement [message #658508 is a reply to message #658423] Tue, 08 March 2011 14:02 Go to previous messageGo to next message
Am 08.03.2011 14:20, schrieb Franz Fehringer:
> installation?
Usually you don't need to care. When you install plug-ins into Eclipse
p2 will automatically resolve any dependencies from referenced/known
sites. P2 will also ensure that only working bundles will be installed.
The things in Orbit don't provide any functionality to Eclipse
out-of-the box. They are 3rdparty libraries packed as OSGi bundles which
are then used by Eclipse plug-ins.
-Gunnar
Gunnar Wagenknecht
Re: GWT missing requirement [message #903417 is a reply to message #658508] Thu, 23 August 2012 10:44 Go to previous messageGo to next message
Oliver Koch is currently offline Oliver Koch
Member
Am 08.03.2011 20:02, schrieb Gunnar Wagenknecht:
>> installation?
> -Gunnar
So far, when adding certain features of orbit to an eclipse target
platform, there happen to be no errors in resolving any dependencies.
But when selecting the all orbit entry on the update site, the error
with GWT appears when resolving the target platform contents
Re: GWT missing requirement [message #903576 is a reply to message #903417] Fri, 24 August 2012 07:52 Go to previous message
Am 23.08.2012 16:44, schrieb Oliver Koch:
The GWT user bundle has a dependency that will never be satisfiable. It
was introduced in order to prevent it ever from being installed and
started into a running framework.
Thus, whenever you want to work with the GWT User bundle you need to
uncheck "Include required software" and check "Include all environments".
HTH,
Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Previous Topic:org.w3c.dom.svg broken in Eclipse 3.7?
Next Topic:How to use logback Orbit bundles?
Current Time: Sun May 19 17:27:50 EDT 2013
Powered by FUDForum. Page generated in 0.01891 seconds
