Home » Newcomers » Newcomers » Debugging not working while running works
Debugging not working while running works [message #903393] Thu, 23 August 2012 09:22 Go to next message
Quint Missing name is currently offline Quint Missing name
I've been having problems debugging my code in Eclipse. For some reason debugging does not work. Building an executable works fine. I can run it in terminal but when I want to debug, it crashes. Here is my simple code.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
int main(void)
  static const char filename[] = "test.txt";
  FILE *file = fopen ( filename, "r" );
  if ( file != NULL )
    char line [ 128 ];
    while ( fgets ( line, sizeof line, file ) != NULL )
      fputs ( line, stdout );
    fclose ( file );
  else
    perror ( filename );
  return 0;
The debugger runs until fopen and than it crashes and says:
Can't find a source file at "../sysdeps/wordsize-64/../../libio/iofopen.c"
Locate the file or edit the source lookup path to include its location.
This while normally running the code (ctrl+F11) does give the desired result. Also running the executable in terminal gives the desired result. Anyone have ideas?
Re: Debugging not working while running works [message #903399 is a reply to message #903393] Thu, 23 August 2012 09:35 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
On 8/23/2012 7:22 AM, Quint Mising name wrote:
> #include <stdio.h>
> [snip]
You might get more relevant help in the Eclipse CDT forum where C/C++
development questions are answered.
Re: Debugging not working while running works [message #903400 is a reply to message #903399] Thu, 23 August 2012 09:42 Go to previous message
Moved to CDT forum
Previous Topic:ClassNotFoundException when running JUnit test
Next Topic:change font and colors
Current Time: Wed May 22 20:27:58 EDT 2013
Powered by FUDForum. Page generated in 0.01586 seconds
